Raspberry Pi Forum Raspberry pi won't display
  • Replies 10 replies
  • Subscribers 677 subscribers
  • Views 1081 views
  • raspberry
  • helpme
  • pi
i am using a vga monitor and i have my raspberry pi displaying through the hdmi using an HDMI CONVERTER and a VGA lead.
to get this working i had to uncomment the hdmi_1 or something . however i recently install the latest version on raspbain and it
booted with out a problem. however when i went to use it this morning i found that the monitor would not display anything. The ACT
light was flashing green and a green light on the monitor came on to show there was an imput but nothing but a black screen.
any ideas?????
Thanks for any help
  • johnbeetem
    johnbeetem over 11 years ago
    There's a bunch of lore on using HDMI->VGA converters at the RasPi Wiki:
    http://elinux.org/RPi_Screens#RGB_analog.2FVGA
    http://elinux.org/RPi_VerifiedPeripherals#HDMI-.3EVGA_converter_boxes
    There might be something useful there.  Since your converter used to work and now doesn't, I would suspect a hardware problem.  If your converter is powered by RasPi rather than its own external power supply, one possibility is that diode D1 has burned out.  It's only designed to supply 200 mA at most so if you draw more than that it could burn out and stop supplying 5V for the converter box.  Diode "D1" and other lore at the RasPi Wiki was written for RasPi Model B and may not apply to B+ or A+.
  • Problemchild
    Problemchild over 11 years ago in reply to johnbeetem
    There does indeed seem to be a lot of black magic going on with this tech ...I would suggest trying this on a PC and see if this gives the same or different results
    i tried displaying through my laptop n this works fine.
  • Problemchild
    Problemchild over 11 years ago in reply to Former Member
    What happens if you put the old version back on the SDCARD does the problem go away ?
  • markvenn
    markvenn over 11 years ago
    Can you drop the contents of your config file from /boot here in case something has been corrupted?
    Former Member over 11 years ago in reply to markvenn
    i tried running my pi through my hdmi tv and it works fine so i am guessing something wrong with the hdmi to vga converter
    any ideas
    Former Member over 11 years ago in reply to Former Member
    i have just opened up my vga converter and found several wires louse and i ideas how to re soldering the wires back together
  • johnbeetem
    johnbeetem over 11 years ago in reply to Former Member
    Jacob Nichols Cook wrote:
    i tried running my pi through my hdmi tv and it works fine so i am guessing something wrong with the hdmi to vga converter... any ideas?
    I'd make sure the HDMI-to-VGA converter is getting power.  You didn't say whether it has an external power supply or draws +5V from RasPi.  If RasPi is supplying power for the converter, check that 5V is getting through D1 OK.  This assumes you have a RasPi Model A or B, and not a B+ which uses an IC for HDMI 5V.
    This just occurred to me: one way a working RasPi starts to fail is if polyfuse F3 (on Models A and B, F1 on B+) misbehaves and increases in resistance.  This can causes any of the symptoms you get with an iffy power supply.  So I'd recommend checking for power supply problems: see the RasPi Troubleshooting Wiki: http://elinux.org/R-Pi_Troubleshooting#Troubleshooting_power_problems
    it draws 5V from the pi and i am using a raspberry pi model B
  • Problemchild
    Since it worked before and works on a computer  but now it does not work after the OS update have you tried going back to the old OS yet ?
