Raspberry Pi Forum Cirrus Logic Audio Card working on the Raspberry Pi 2
  • Replies 165 replies
  • Subscribers 715 subscribers
  • Views 26998 views
  • wolfson
  • raspberry
  • audio
  • pi
  • cirrus
  • rpi2
  • raspeberry_pi_accessories
  • pi2
Hi all!
As you might know, Cirrus Logic's main kernel source branch recently switched to 3.18.
My first thought was "Hmm, that means the Cirrus Logic card could finally work on the RPi2..."
I have built a couple of 3.18 kernels for my B+ and RPi2 and I have managed to get both models to produce sound image
It's still early days, i.e. there are possibly bugs and glitches to fix, but for those of you who would like to try it out I've made an image file that you can download here:
https://drive.google.com/file/d/0BzIaxMH3N5O1cmJ1bFhMcG1hc0E/view?usp=sharing
The file is a 1.3 GB zip. Uncompressed size is 3.1 GB, so it fits comfortably on a 4 GB card.
The image is based on the standard 2015-02-16-raspbian-wheezy image from the Foundation that you flash to a SD card for a fresh install.
I have only added my kernels and set up the configuration files to get the card going.
It should work on the older B model  with a Wolfson Audio Card too, but I haven't tested that yet.
Have fun!
Ragnar
    e14 Contributor over 11 years ago in reply to e14 Contributor
    No need to recompile, Jack2 from the Raspbian repositories works on the RPi (contrary to Jack1 which needs a patch to work around the bus error). You need to tell it where the dbus session bus is though:
    export DBUS_SESSION_BUS_ADDRESS=unix:path=/run/dbus/system_bus_socket
    Then it probably still won't start because Jack2 can not acquire the sound card, you can fix that by adding the following lines to /etc/dbus-1/system.conf:
      <policy user="pi">
            <allow own="org.freedesktop.ReserveDevice1.Audio1"/>
      </policy>
    More info here: http://wiki.linuxaudio.org/wiki/raspberrypi#running_jack
    I patched the kernel in my image to add mmap support for I2S cards. The stock Raspbian kernel doesn't have it, but the old Wolfson 3.10 kernel does.
    Could you please provide me with the entire patch file, I'm getting a malformation error.
    That's why I built my own, without dbus. Almost all of my Pis are headless, thus no X server running and consequently no dbus service.
    Since mine are headless too, this might be interesting. Where did you disable the dbus service?
    After inserting this in /etc/dbus-1/system.conf and adding export DBUS_SESSION_BUS_ADDRESS=unix:path=/run/dbus/system_bus_socket
      <policy user="pi">
            <allow own="org.freedesktop.ReserveDevice1.Audio0"/>
      </policy>
    I was able to start jack2 via jackd -v -P70 -p16 -t2000 -d alsa -dplughw:0,0 -p 1024 -n 3 -r 44100 -s but only with the increased buffer size and -dplughw:0,0
    which might not start in RT and does not make a stable impression.
    Jack: JackPosixThread::StartImp : create non RT thread
    Jack: JackPosixThread::ThreadHandler : start
    Jack: JackThreadedDriver::Init real-time
    Jack: JackPosixThread::AcquireRealTimeImp priority = 70
    Jack: JackAlsaDriver::Read warning fBufferSize = 1024 nframes = 2048
    pi@raspberrypi2 ~ $ jackd -v -P70 -p16 -t2000 -d alsa -dhw:0,0 -p 128 -n 3 -r 44100 -s
    jackdmp 1.9.9
    Copyright 2001-2005 Paul Davis and others.
    Copyright 2004-2012 Grame.
    jackdmp comes with ABSOLUTELY NO WARRANTY
    This is free software, and you are welcome to redistribute it
    under certain conditions; see the file COPYING for details
    JACK server starting in realtime mode with priority 70
    Jack: playback device hw:0,0
    Jack: capture device hw:0,0
    Jack: frames per period = 128
    Jack: apparent rate = 44100
    Jack: JackDriver::Open capture_driver_name = hw:0,0
    Jack: JackDriver::Open playback_driver_name = hw:0,0
    Jack: Check protocol client = 8 server = 8
    Jack: JackEngine::ClientInternalOpen: name = system
    Jack: JackEngine::AllocateRefNum ref = 0
    Jack: JackPosixSemaphore::Allocate name = jack_sem.1000_default_system val = 0
    Jack: JackEngine::NotifyAddClient: name = system
    Jack: JackGraphManager::SetBufferSize size = 128
    Jack: JackConnectionManager::DirectConnect first: ref1 = 0 ref2 = 0
    Jack: JackGraphManager::ConnectRefNum cur_index = 0 ref1 = 0 ref2 = 0
    Jack: JackDriver::SetupDriverSync driver sem in flush mode
    control device hw:0
    control device hw:0
    audio_reservation_init
    Acquire audio card Audio0
    creating alsa driver ... hw:0,0|hw:0,0|128|3|44100|0|0|nomon|swmeter|soft-mode|32bit
    control device hw:0
    configuring for 44100Hz, period = 128 frames (2.9 ms), buffer = 3 periods
    ALSA: mmap-based access is not possible for the capture stream of this audio interface
    ALSA: cannot configure capture channel
    Jack: JackDriver::Close
    Jack: JackConnectionManager::DirectDisconnect last: ref1 = 0 ref2 = 0
    Jack: JackGraphManager::DisconnectRefNum cur_index = 0 ref1 = 0 ref2 = 0
    Jack: JackEngine::ClientInternalClose ref = 0
    Jack: JackEngine::ClientCloseAux ref = 0
    Jack: JackGraphManager::RemoveAllPorts ref = 0
    Jack: JackPosixSemaphore::Destroy name = jack_sem.1000_default_system
    Jack: ~JackDriver
    Cannot initialize driver
    Jack: no message buffer overruns
    Jack: JackPosixThread::Stop
    Jack: JackPosixThread::ThreadHandler : exit
    JackServer::Open failed with -1
    Jack: Succeeded in unlocking 13589216 byte memory area
    Jack: JackShmMem::delete size = 0 index = 0
    Jack: ~JackDriver
    Jack: Succeeded in unlocking 1040 byte memory area
    Jack: JackShmMem::delete size = 0 index = 1
    Jack: Cleaning up shared memory
    Jack: Cleaning up files
    Jack: Unregistering server `default'
    Failed to open server
    I have noticed that you can get invisible junk characters if you copy-paste from this web site, especially from the "view plain" window.
    While you're at it, you might be interested in a patch supplied by hiassoft that solves some problems when switching sampling rates, described here Issues with samplerates below 44.1kHz
    Building jack with its default compilation mode produces a dbus-less version. You have to explicitly give it a --dbus flag at configure time to enable it.
    Ragnar
    cirrus_mmap_v2.patch.zip
    0638.fll.patch.zip
    Try using -hw:sndrpiwsp instead of -hw:0,0 and use the appropriate Wolfson amixer scripts to enable the inputs and outputs you want to to use with JACK before starting JACK.
    I applied the mmap patch. The fll patch had to be applied manually to ~/code/rpi-linux/sound/soc/bcm/rpi-cirrus-sound-pi.c since the patch was looking for a rpi-cirrus-sound-pi.c.orig
    Recompiled the kernel but JACK seems to miss the alsa driver I should have inclueded with ./waf configure --alsa but it requires version 1.0.18
    What kind of package of alsa is that?
    I was under the impression of this being the alsa version:
    pi@raspberrypi2 ~/jack2 $ cat /proc/asound/version
    Advanced Linux Sound Architecture Driver Version k3.18.9-v7+.
    Jeremy, I used the Playback_to_Lineout.sh script but I got sound from the headset port aswell.
    And the jack errors with missing alsa driver:
    pi@raspberrypi2 ~/jack2 $ jack_control start
    Traceback (most recent call last):
      File "/usr/local/bin/jack_control", line 399, in <module>
        main()
      File "/usr/local/bin/jack_control", line 158, in main
        bus = dbus.SessionBus()
      File "/usr/lib/python2.7/dist-packages/dbus/_dbus.py", line 211, in __new__
        mainloop=mainloop)
      File "/usr/lib/python2.7/dist-packages/dbus/_dbus.py", line 100, in __new__
        bus = BusConnection.__new__(subclass, bus_type, mainloop=mainloop)
      File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 122, in __new__
        bus = cls._new_for_bus(address_or_type, mainloop=mainloop)
    dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
    pi@raspberrypi2 ~/jack2 $ jackd  -P70 -p16 -t2000 -d alsa -dhw:sndrpiwsp -p 1024 -n 3 -r 44100 -s
    jackdmp 1.9.11
    Copyright 2004-2014 Grame.
    Unknown driver "alsa"
    It's the ALSA developer files and libraries.
    sudo apt-get install libasound2-dev
    The scripts are cumulative, switching an output on does not switch the others off. That's why Reset_paths.sh exists, it switches everything off.
    Ragnar
    I see, Jeremy just meant it is not advisable to configure the soundcard after starting JACK.
    It's getting closer: JACK2 compiled successfully and I can start the daemon. Although the build had many warnings (http://pastebin.com/Q22hQBV6) and not everything works as expected. It is still looking for the dbus.
    pi@raspberrypi2 ~ $ jack_control start
        main()
        mainloop=mainloop)
    pi@raspberrypi2 ~ $ export DBUS_SESSION_BUS_ADDRESS=unix:path=/run/dbus/system_bus_socket
        main()
      File "/usr/local/bin/jack_control", line 160, in main
        controller = bus.get_object(service_name, "/org/jackaudio/Controller")
      File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 241, in get_object
        follow_name_owner_changes=follow_name_owner_changes)
      File "/usr/lib/python2.7/dist-packages/dbus/proxies.py", line 248, in __init__
        self._named_service = conn.activate_name_owner(bus_name)
      File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 180, in activate_name_owner
        self.start_service_by_name(bus_name)
      File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 278, in start_service_by_name
        'su', (bus_name, flags)))
      File "/usr/lib/python2.7/dist-packages/dbus/connection.py", line 651, in call_blocking
        message, timeout)
    dbus.exceptions.DBusException: org.freedesktop.DBus.Error.ServiceUnknown: The name org.jackaudio.service was not provided by any .service files
    The daemon starts but clients are not able to connect
    pi@raspberrypi2 ~ $ jack_simple_client
    Cannot open jack_simple_client client
    jack_client_open() failed, status =
    pi@raspberrypi2 ~/jack2 $ jackd -P70 -p16 -t2000 -d alsa -dhw:0,0 -p 128 -n 3 -r 44100 -s
    jackdmp 1.9.11
    self-connect-mode is "Don't restrict self connect requests"
    ALSA: final selected sample format for capture: 32bit integer little-endian
    ALSA: use 3 periods for capture
    ALSA: final selected sample format for playback: 32bit integer little-endian
    ALSA: use 3 periods for playback
    JackPosixSemaphore::Signal name = jack_sem.1000_default_system already deallocated!!
    JackAudioDriver::ProcessGraphAsyncMaster: ResumeRefNum error
    status error: Bad file descriptor
    ALSA: prepare error for playback on "hw:0,0" (File descriptor in bad state)
    JackAudioDriver::ProcessAsync: read error, stopping...
    JackPosixProcessSync::LockedTimedWait error usec = 5000000 err = Connection timed out
    Driver is not running
    Cannot create new client
    ^CJack main caught signal 2
    Segmentation fault
    Where have you installed your self-compiled jackd? Mine lives in /usr/local/bin and I've put a symlink to it in /usr/bin because that's where some of the jack_* utilities look for it.
    It's jack_control and jack_simple_client that's trying to use dbus to start a jack daemon.
    If they actually manage to start a jack daemon, it might be because they have found the old dbus-enabled jackd in /usr/bin
    Ragnar
    I used the default path when executing sudo ./waf install
    I also deinstalled and removed all jack related binaries to make sure only the newly compiled dbus-less version gets used.
    Maybe I checked out a different JACK2 version than you did?
    pi@raspberrypi2 ~ $ ll /usr/local/bin/
    total 520
    drwxrwsr-x 2 root indiecity  4096 Feb 16 13:29 indiecity
    -rwxr-xr-x 1 root staff      8918 May 10 17:41 jack_alias
    -rwxr-xr-x 1 root staff      9393 May 10 17:41 jack_bufsize
    -rwxr-xr-x 1 root staff     12033 May 10 17:41 jack_connect
    -rwxr-xr-x 1 root staff     15725 May 10 13:14 jack_control
    -rwxr-xr-x 1 root staff     12738 May 10 17:41 jack_cpu
    -rwxr-xr-x 1 root staff      7747 May 10 17:41 jack_cpu_load
    lrwxrwxrwx 1 root staff        12 May 10 13:24 jack_disconnect -> jack_connect
    -rwxr-xr-x 1 root staff      9344 May 10 17:41 jack_evmon
    -rwxr-xr-x 1 root staff      7778 May 10 17:41 jack_freewheel
    -rwxr-xr-x 1 root staff     13053 May 10 17:41 jack_iodelay
    -rwxr-xr-x 1 root staff     12159 May 10 17:41 jack_latent_client
    -rwxr-xr-x 1 root staff     10665 May 10 17:41 jack_load
    -rwxr-xr-x 1 root staff     13849 May 10 17:41 jack_lsp
    -rwxr-xr-x 1 root staff     14799 May 10 17:41 jack_metro
    -rwxr-xr-x 1 root staff     12954 May 10 17:41 jack_midi_dump
    -rwxr-xr-x 1 root staff     31878 May 10 17:41 jack_midi_latency_test
    -rwxr-xr-x 1 root staff      9933 May 10 17:41 jack_midiseq
    -rwxr-xr-x 1 root staff     10275 May 10 17:41 jack_midisine
    -rwxr-xr-x 1 root staff      7325 May 10 17:41 jack_monitor_client
    -rwxr-xr-x 1 root staff     14606 May 10 17:41 jack_multiple_metro
    -rwxr-xr-x 1 root staff     38948 May 10 17:41 jack_netsource
    -rwxr-xr-x 1 root staff      7864 May 10 17:41 jack_samplerate
    -rwxr-xr-x 1 root staff     12988 May 10 17:41 jack_server_control
    -rwxr-xr-x 1 root staff     11743 May 10 17:41 jack_session_notify
    -rwxr-xr-x 1 root staff      8316 May 10 17:41 jack_showtime
    -rwxr-xr-x 1 root staff     10132 May 10 17:41 jack_simple_client
    -rwxr-xr-x 1 root staff     10913 May 10 17:41 jack_simple_session_client
    -rwxr-xr-x 1 root staff     66387 May 10 17:41 jack_test
    -rwxr-xr-x 1 root staff     10479 May 10 17:41 jack_thru
    -rwxr-xr-x 1 root staff      7682 May 10 17:41 jack_unload
    -rwxr-xr-x 1 root staff      9667 May 10 17:41 jack_wait
    -rwxr-xr-x 1 root staff      8064 May 10 17:41 jack_zombie
    -rwxr-xr-x 1 root staff     28881 May 10 17:41 jackd
    pi@raspberrypi2 ~ $ ll /usr/bin/jack*
    lrwxrwxrwx 1 root root 27 May 11 08:52 /usr/bin/jack_control -> /usr/local/bin/jack_control
    lrwxrwxrwx 1 root root 33 May 11 08:59 /usr/bin/jack_simple_client -> /usr/local/bin/jack_simple_client
    lrwxrwxrwx 1 root root 20 May 11 08:50 /usr/bin/jackd -> /usr/local/bin/jackd
        main()
        mainloop=mainloop)
    PS: The fll patch worked, I can now play my wave testfile with aplay!
    Mine is older than yours (1.9.9.5) but otherwise  the same.
    But, jack_control has only one purpose; to control jack-dbus. It's a python script, it isn't configured or built, just copied.
    Ragnar
