Raspberry Pi Forum Noise Issues on Raspberry Pi A+
  • Replies 9 replies
  • Subscribers 707 subscribers
  • Views 1302 views
  • audio
  • issues
  • noise
Hello All - I just purchase the element14 Pi A+ at microcenter and am having a noise issue with the board. Immediately upon power up the 1/8 output is extremely noisy, to the point that it would be useless for my application (soundfont player) Also there's all sort of weird aliasing on the audio, particularly on the low end. Does anyone else have this issue, or is it possible that it's just my board and it's defective? Do you think the HDMI out would fare any better?  Any help is greatly appreciated. Thanks.
Best,
Bob
    0 shabaz over 11 years ago
    The HDMI would fare _much_ better. The 1/8" jack output is not hi-fi, and expect some electronic noise on it. It is a very basic audio output.
    The HDMI output is digital so will be bit-perfect.
    Another alternative is the Cirrus audio card which plugs on top, and offers high quality audio.
    0 e14 Contributor over 11 years ago in reply to shabaz
    Thanks for the fast response! I will definitely try that, maybe I can rustle up an HDMI to audio adapter.  I also ordered a HiFiBerry DAC+ to try. So my board is not defective, and this is normal? I would have expected a bit better than this. Learning as I go. Thanks!
    0 shabaz over 11 years ago in reply to e14 Contributor
    Hi Bob,
    Usually the entire system needs to be examined when it comes to analog audio - there could be screening issues, power supply issues, ground loops and so on. None of this is under control because no-one knows
    which power supply will get used with the RPI, which audio amplifier, which cables, etc. The RPI has no separation of analog or digital supplies either - (guessing - there is no schematic).
    As you probably know, with digital audio this matters far less, and while there may be jitter issues depending on the overall system, many people can't hear it - with digital the leap in quality is significant compared to the analog jack output.
    The HiFi berry should in theory be good - it uses a fairly good DAC from TI - I used a similar DAC in a BeagleBone Black quite a while ago and the quality I got was good. There is a recorded file at that link if you want to study the sound output.
    The Cirrus card can do audio input too - and should be extremely good quality, since the entire board is custom designed by Cirrus.
    I've not used the Hi-fi berry nor Cirrus, so these are just opinions.
    (Link appears broken, URL is BBB - Building a DAC - part 2 )
  • gadget.iom
    0 gadget.iom over 11 years ago
    Bear in mind that the Raspberry Pi was initially intended for teaching computer science in Schools. High fidelity audio wasn't top of their agenda.
    Thanks Shabaz - I will definitely check out the Cirrus card too.  Interesting, as I am new to this stuff, I didn't really ponder the potential issues of open source hardware and consistency/quality.  A little learning curve for me I guess. If I learn anything I'll post it back here. Thanks again for your help!
    0 balearicdynamics over 11 years ago
    Hello Bob, unfortunately it is true. I had the same problem and I was obliged to dedicate a Raspberry PI (B+) to the audio output with a Cirrus Logic Audio Card that instead works perfectly. As the problem with this card is the need of a non-upgradable and dedicated version of the raspian Linux (at least until the actual date), if you plan to make and / or install something special I suggest to check if it is possible to be done before equipping - eventually - the PI with this board. It is a really great board but the real-time kernel really is a great limitation in such case.
    Enrico
    0 e14 Contributor over 11 years ago in reply to balearicdynamics
    Hi Enrico - Thanks for the info, are you referring to the HiFiBerry board? Clearly my lack of experience with all of this is going to get me into some trouble. image  I appreciate such a responsive community. I thought my post was going to be a tree falling in the woods (no one heard it, doesn't exist) so it's nice to see. Thanks much!
    0 balearicdynamics over 11 years ago in reply to e14 Contributor
    No ( I have not read about this board until now image) I refer to the former Wolfson technologies Cirus Logic (see the product link : http://www.element14.com/community/community/raspberry-pi/raspberry-pi-accessories/cirrus_logic_audio_card ), specific version for the Raspberry PI. If you have in mind to acquire one, let me know that some tricks I have discovered may save a lot of time image
    Enrico
    Thanks much, Enrico. I will keep it in mind image
