Raspberry Pi Forum Best device for Gigabit Ethernet traffic testing and WiFi Site Surveying
  • Replies 13 replies
  • Answers 2 answers
  • Subscribers 706 subscribers
  • Views 2729 views
  • wifi
  • raspberry-pi
  • networking
bobalexander
bobalexander over 10 years ago
Hi everyone!
I am currently using a Raspberry Pi 2 running IPERF https://iperf.fr/ to test bandwidth on a WiFi/LAN network.
As the Pi is only 100Mbps I am only able to exercise tests up to the 100M mark (~96 Mbits/sec).
Is anyone aware of a better small platform that I could setup iperf on to run tests at a higher bandwidth?
Ideally, it could run at GigE speeds but my current needs only require ~450Mbps for 802.11n WiFi testing.
BTW, this is nothing permanent or attached to a production network so security is not a concern.
Thanks!
  • Robert Peter Oakes
    0 Robert Peter Oakes over 10 years ago
    Banna PI may do the trick, it has 1GB ethernet
    http://www.bananapi.org/p/product.html
  • Problemchild
    0 Problemchild over 10 years ago
    Have you considered one of the GigE attached Odroids like the XU3?
  • bobalexander
    0 bobalexander over 10 years ago in reply to Robert Peter Oakes
    I looked into that and the GigE port does sound promising but other users are stating only ~106 Mb/s, but it may have been a mis-configuration or sub-optimal test...
    http://www.lemaker.org/thread-14972-1-1.html
    Another user reported 'above' 750 Mbits/sec which would be perfect.
    *corrected MB/s to Mb/s*  image
  • bobalexander
    0 bobalexander over 10 years ago in reply to Problemchild
    No, I haven't looked at them - I will dig in.
    Thanks!
  • Problemchild
    0 Problemchild over 10 years ago in reply to bobalexander
    That's for a Banana Pi and it's MBytes per second not MBit so that is prity much the full 1Gig E exactly what you want !!!
    0 Robert Peter Oakes over 10 years ago in reply to Problemchild
    Are you two related, is this a family feud !! lol
    yes though, your correct I marked it as 1GB instead of the correct Gb  (Which is a way different value)
  • bobalexander
    Yes, I see the error there!  image
    I have a friend bringing me his Banana Pi after lunch - will let you know how it goes!
  • bobalexander
    I wish! Thanksgiving would be so much more interesting!!  image
  • Problemchild
    How did the Banana go ?
    Do you have the performance figures ?
  • bobalexander
    The Banana Pi can do pretty well!
    This is the default settings (both Windows and on the Banana) connecting through a gigabit switch:
    From Windows (192.168.1.108 to Banana Pi 192.168.1.175)
    iperf-2.0.5-3-win32>iperf -c 192.168.1.175 -r
    Server listening on TCP port 5001
    TCP window size: 63.0 KByte (default)
    Client connecting to 192.168.1.175, TCP port 5001
    [  4] local 192.168.1.108 port 65006 connected with 192.168.1.175 port 5001
    [ ID] Interval       Transfer     Bandwidth
    [  4]  0.0-10.0 sec  429 MBytes  360 Mbits/sec
    [  4] local 192.168.1.108 port 5001 connected with 192.168.1.175 port 35243
    [  4]  0.0-10.0 sec  570 MBytes   478 Mbits/sec
    I think that will be sufficient for testing 802.11n!
    Thanks!
