Raspberry Pi Forum RP2 audio/video jack Debian
  • Subscribers 707 subscribers
  • Views 996 views
  • debian
  • jack
  • raspberry_pi2
  • audio_video
  • raspberry_pi_space
Hello community of Element 14,
First of all, I'm totally new to Element14, never worked with forums or something so please be gentle. image
Also I'm pretty new to Raspberry so that's where I call your help in.
Due to a lack of money I want to run my Raspberry Pi 2 on an old television through audio/video jack.
This worked with a couple of other OSes but not with Debian (it does work with HDMI).
Is this something that should be changed in the settings or is it even possible?
Thanks in advance,
Renier
    I also posted this question on the Raspberry forum and got it solved.
    If someone has the same problem, you can find my explanation of how i solved it here https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=124747
    Renier
    0 mcb1 over 10 years ago in reply to e14 Contributor
    Renier
    That's great ...
    Do you think it would be helpful if the text was also pasted into this question, since it seems that there were two possibile problems.
    BTW I'm sure you aren't the only one to get caught with this one.
    Well done.
    0 e14 Contributor over 10 years ago in reply to mcb1
    Mark,
    With "the text" you mean the solution?
    If so, I'll paste it in another reply and delete this one after you've confirmed me.
    Kind regards,
    Renier
    For everyone, just as new as I, here an explanation how i manged to solve it.
    When you boot your Raspberry Pi press shift to get into the recovery mode. If your screen stays black, press 1, 2, 3 and 4 separately (this will change it for now to the AV plug, so you can see what to work with).
    Press e to get into the config file. (https://www.raspberrypi.org/documentation/configuration/config-txt.md)
    What I needed to change was stdv_mode, i only needed to remove the # in front of it and at the bottom I changed the NOOBS autogenerate settings, further more I changed the force_hdmi to 0.
    This worked for me and hopefully is someone ever finds this post can solve it with this guide.
    Thanks again DougieLawson, drgeoff and fruitoftheloom for helping me out!
    Renier
    Is the solution i wrote on the Rasp forum.
    Edit: I knew my problem couldn't be in the cable because it worked with other OSes, to make sure your cable works you can check http://www.raspberrypi-spy.co.uk/2014/07/raspberry-pi-model-b-3-5mm-audiovideo-jack/.
    Perfect sir.
    I've found in the past that the 'other site' sometimes removes stuff, etc.
    Cheers
  • Problemchild
    0 Problemchild over 10 years ago in reply to mcb1
    This whole HDMI/Composite video switching/Selection issue seems to be about the most common problem  with the RPI overall it may be worth a section going through the options on this area specifically!
