Raspberry Pi Forum Microstack GPS and Accelerometer on RaspberryPi 2 and Ubuntu Mate
  • Replies 12 replies
  • Subscribers 705 subscribers
  • Views 2164 views
  • Ubuntu
  • 2
  • rasberrypi
  • mate
  • microstack
doubletop
doubletop over 10 years ago
I'm going round in circles trying to get this to work with Ubuntu Mate and its not clear which posts on any website are relevant and which are not.
Here's where I've got to.
$ sudo apt-get install python3-microstacknode
Doesn't work
sudo apt-get install python3-pip
works
sudo pip-3.2 install microstackcommon microstacknode
works if pip-3.2 is changed to pip. However it puts all the files into /usr/local/lib rather than /usr/lib and there are no example files. microstackcommon and microstacknode files have been moved to /usr/lib/ in the existing file structure for python 2.7 python3,4 and python3,5. I got the examples from GitHUb and placed them in a local folder.
As there is no Rasp-config available config.txt has been edited to add
sudo nano /boot/config.txt
and
dtparam=i2c_arm=on
dtparam=spi=on
sudo i2cdetect -y 1
works. However, no device is found
0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:      -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Running the examples accelcat.py
Traceback (most recent call last):
  File "/home/pete/PythonTest/accelcat.py", line 11, in <module>
    with MMA8452Q() as accelerometer:
  File "/usr/lib/python3.4/dist-packages/microstacknode/hardware/accelerometer/mma8452q.py", line 126, in __enter__
    self.init()
  File "/usr/lib/python3.4/dist-packages/microstacknode/hardware/accelerometer/mma8452q.py", line 131, in init
    self.standby()
  File "/usr/lib/python3.4/dist-packages/microstacknode/hardware/accelerometer/mma8452q.py", line 153, in standby
    self.ctrl_reg1.set(self._ctrl_reg1_value)
  File "/usr/lib/python3.4/dist-packages/microstacknode/hardware/accelerometer/mma8452q.py", line 279, in set
    writing_bytes(self.device_address, self.register_address, v))
  File "/usr/lib/python3.4/dist-packages/microstackcommon/i2c.py", line 85, in transaction
    ioctl(self.fd, I2C_RDWR, ioctl_arg)
OSError: [Errno 5] Input/output error
and gpscat.py
  File "/home/pete/PythonTest/gpscat.py", line 3, in <module>
    import microstacknode.gps.l80gps
ImportError: No module named 'microstacknode.gps'
So clearly something is missing  from the pip install so rather than editing and juggling around files please where or how do I find the 'proper' install package that gets everything i need to make this work with Ubuntu Mate?
Pete
  • rew
    0 rew over 10 years ago
    Even though it looks as if the software installation might have been wrong or incomplete....
    you have clear indication that
    * You succeeded in enabling I2C: i2cdetect works!
    * Your PI does NOT have a connection to the I2C devices: I2cdetect does NOT report any devices.
    So: Check your hardware! (Both i2cdetect and python are trying to tell you: no i2c device found at that address).
  • doubletop
    0 doubletop over 10 years ago in reply to rew
    Roger
    Thanks for taking the time to reply.
    I'd hope the hardware was fine Its a brand new RasPi 2, Microstack baseboard, accelerometer and GPS received form Element14 in the past week. The Ubuntu Mate was downloaded in the past week, installed on a new 32Gb class10 SDHC card and updates applied
    I'm keen to get a clean build that works properly and not subject to hacks and tweaks to make it work. Once I’ve got it going I plan to blow it all away and do a clean build
    Pete
  • rew
    0 rew over 10 years ago in reply to doubletop
    I haven't investigated what hardware you have. But the part "raspberry pi" I know what it is and it seems to be functioning. The other stuff seems to be "not connected to the pi" when viewed from the pi. If what you have is a simple board that plugs on the 'pi, make sure that it's correctly positioned and configured. Double check that your device is supposed to be on I2C. (I've had one of my clients complain that i2c-detect didn't see any devices, while he had an SPI device....). If you need wires to connect it check the wires. Or.... Post a picture.
  • clem57
    0 clem57 over 10 years ago in reply to doubletop
    doubletop
    Have you seen this http://www.microstack.org.uk/assets/gps/FormattedGPSgettingstarted.pdf?
    Clem
  • mconners
    0 mconners over 10 years ago in reply to clem57
    Reading that clem57 that looks like it should be communicating via the serial port and not I2C at all.
    But, I am not familiar with the setup he has.
    Mike
  • clem57
    There may be this raspbian - Microstack Accelerometer not working. I2C issue? - Raspberry Pi Stack Exchange which requires a jumper.
  • mconners
    0 mconners over 10 years ago in reply to mconners
    Oh, I guess that  doc is only for the GPS. The accelerometer may very well use I2C.
    One issue to check is to make sure you have a power supply capable of running both the RaspberryPi and the microstack add on module and boards.
    You don't mention what type and rating of the power supply you are using.
    Mike
  • doubletop
    Clem has identified the issue with the accelerometer. I have one of 'the couple' of units that don't have the link on JP1 on the board. Microstack/Element14 need to add clearer instructions to purchasers of this board.
    The GPS is another issue the clue is here
    GPSD Installation Instructions
    Right down the bottom Raspi tips
    "Second you need to tell the boot process to load the pps_gpio module and attach /dev/pps0 to GPIO ping 4. Do that by adding this line to the bottom of /boot/config.txt: dtoverlay=pps-gpio,gpiopin=4"
    Then use the Adafruit instructions  to test it
    https://learn.adafruit.com/adafruit-ultimate-gps-hat-for-raspberry-pi/pi-setup
    Next problem was this error
    The install of the microstackcommon and microstacknode not only goes to the wrong folders /usr/local/lib rather than /usr/lib it is put in an extra folder usr/lib/python3.4/dist-packages/microstacknode/hardware/gps/l80.py if all the modules are moved up to usr/lib/python3.4/dist-packages/microstacknode/gps/l80.py the modules can be found by the code.
    I'm now getting access permission errors and that need to be looked into, but progress has been made
    Basically my assessment so far is that Microstack and Element14, as the exclusive suppliers, need to sort out their crap documentation and provide something that is up to date and complete.
    Pete
  • clem57
    Take a look at https://github.com/microstack-IoT/python3-microstacknode/issues/5 image
    Clem
  • clem57
    0 clem57 over 10 years ago in reply to clem57
    Some doc worth checking http://python3-microstacknode.readthedocs.org/en/latest/index.html
    C
