Raspberry Pi Forum PiFace RTC on Raspberry Pi2: still losing time on reboot!
  • Replies 24 replies
  • Subscribers 709 subscribers
  • Views 4514 views
  • clock
  • pi
  • rtc
  • raspberrypi
  • date
  • settings
  • piface
Hi!
I bought a PiFace RTC and I'm trying it on a Raspberry Pi 2 Model B. I followed the many guides I found on the internet, but I'm still having problem with the date: when I reboot, the system time is always set to Jan 1, 1970! It seems to be in a reset condition.
The I2C detects well the device at the address 0x6F, and the battery is ok.
After the execution of the .sh script as written in the PiFace RTC user guide, I set the actual date with "sudo date -s "12 jan 2016 10:30:00",
set the i2c module from raspi-config.
I triyed in so many ways but I really can't understand what I'm doing wrong!
Any idea would be appreciated!
Andrea.
  • mconners
    0 mconners over 10 years ago in reply to e14 Contributor
    After reading this and a couple of similar posts, I decided to try hooking up a similar device, the DS 1307, in the same manner. I wrote a blog about it here
    Enabling RTC on the Raspberry Pi 2
    Mike
    0 e14 Contributor over 10 years ago in reply to mconners
    Mike
    Thanks Mike, this is very interesting and well described! My rtc device has a MCP7940N onboard. Can I ask you which particular RTC commercial board with the DS1307 did you used in your guide?
  • mconners
    I tried to figure out the manufacturer the other day and I can not remember where I purchased it. There is a good chance it's a Chinese board I bought from ebay. Adafruit sells a kit, but I'm not sure where the best source for you would be in Europe.
    Mike
  • mconners
    Looking at your post above, I noticed one of the lines in your rc.local has
    1. echo mcp7941x 0x6f > /sys/class/i2c-dev/i2c-1/device/new_$
    does it really have a $ at the end? Is that valid? The examples I've seen, and a code snippet I found for the I2C driver, said new_device
    in fact in my example on my blog post, I had
    echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-1/new_device
    notice, there is a difference
    vs
    /sys/class/i2c-dev
    although I see that both exist on my pi
    I'd also consider commenting out the calibrate line in the rc.local
    Mike
