Raspberry Pi Forum Waiting for SD card (settings partition)
  • Subscribers 707 subscribers
  • Views 2548 views
  • raspberry_pi_getting_started
Ok, this is gonna be a long post, so hold on to your boot straps...
I bought this Raspberry Pi 2 the other day, and tried to use and Amazon Kindle Fire Power connector with 0.85 Amps. I saw in the getting started info that it really needs 1.8 amps or more (up to 2.5 amps) to do its thing. I figured I would give it a shot anyway. Nothing ventured, nothing gained, right? So anyway, I saw a little rainbow, and was told that it meant that there was not enough power. So I went and bought a 2 amp charger (this cost fully half of what the Pi cost) and all is well with the world. Right...
I bought a 4GB SD card that had NOOBS pre-installed on it. Unfortunately, this did NOT have a microSD card in it like I thought it might. The dealer offered to buy it back, but I declined, so that is on me.
I tried the old copy/paste from my computer. (Copy from the SD Card onto my computer, then paste to a 4 GB microSD card I had from another application) I was able to get the files from my computer to the 4 GB microSD card, but when I put it into my Pi, I had the red power light lit, and also the green act light was constant. I was told that the NOOBS software might be at issue, so I downloaded the Raspian-Jessie software and after trying to put the file onto the 4 GB card, it wouldn't let me because the file was too large to install it with the iso file. So, I went and bought a 32 GB microSD card put out by Toshiba. (It cost a dollar less than the SanDisk, and I am a cheap broke bast... err... you get the drift... So I bought it because I didn't see any other difference.)
When I finally got it up and running, I was going to try to host my web site. I wasn't far into it when I ran into an user name/password issue. At this time, there should have only been two user names and passwords on this device. (The pi/raspberry, and the username/password I defined.) Neither one of them worked so since I wasn't very far into it, I decided to go ahead and reformat the SD card (32GB) and start from scratch. (btw, I have used both gparted and SDformatter to format these SD cards) Here is where the current issue lies. The Pi will no longer boot. This issue is Waiting for SD card (settings partition). I have tried reformatting the card many times to no avail.
Any help in this matter would be GREATLY appreciated.
Thanks in advance!
Jeff
  • clem57
    0 clem57 over 10 years ago
    Jeff,
         Here it is from start to finish How to Make a Raspberry Pi Web Server - wikiHow
    Clem
  • gadget.iom
    0 gadget.iom over 10 years ago
    It sounds like some of the linux partitions still exist on the card. There are instructions available on the Raspberry Pi Documentation pages regarding formatting of SD cards for NOOBS.
    https://www.raspberrypi.org/documentation/installation/noobs.md
    Take a look at the "HOW TO FORMAT AN SD CARD AS FAT" section.
    Paul
    Ok, I got it working again! =)
    I had to download an img writer (Win32DiskImager gotten at SourceForge.net) after I reformatted yet again, and this time it became bootable again and installed the raspbian-jessie.
    Once I got it installed properly, it booted up like a charm =)
  • clem57
    0 clem57 over 10 years ago in reply to e14 Contributor
    Great, same as step 2 in How to Make a Raspberry Pi Web Server - wikiHow
    Extract the image to the SD card. To do this, we need a tool called the Win32 Disc Imager. A link for this is also available in the sources section. Now open the tool, navigate to the drive letter that your SD card is in, select the location of the Raspberry Pi OS image, and select burn.
    A google would send you to several sources to download.
    Clem
    So some of the Kodi sites mention using the program SDFormatter to properly format the SD card. I had this exact problem and had tried a number of times to format and load NOOBS and received the same error. I was able to resolve it by choosing under options, Format Type = Full (Overwrite) in addition to Format Size Adjustment = ON. This took much longer but the next time I booted the Raspberry Pi but, it worked like a charm.
