Raspberry Pi Forum inhibit buttons whilst running script?
  • Replies 39 replies
  • Answers 7 answers
  • Subscribers 709 subscribers
  • Views 4763 views
  • python
  • raspberry pi
  • piface
brew
brew over 10 years ago
Hi there I'm trying to use my Raspberry Pi 1B and PiFace to run a little interactive museum exhibition.
Process is Pi is in standby, Standby.py runs from rc.local Relay 1 is closed as this is the main light in the room,
Button Press (SW1) initiates the show
GoShow.py runs, this closes a number of replays which change the lights in the space and trigger a media player for the video the Pi plays a audio file.
I want to inhibit the button when GoShow is active, I've tried to 'de-listen' under the GoShow.py but no luck.
https://github.com/Brewj/Event-Trigger
Anyone any ideas?
Cheers
Brew
  • clem57
    0 clem57 over 10 years ago
    Easy. when the show starts save a file like start_show. When the show ends delete file start_show. If Standby.py se file start_show, do nothing.
    Clem
  • jack.chaney56
    0 jack.chaney56 over 10 years ago
    Seems the thing you are looking for is what is called a semaphore. Which is an OS feature.  Simply put, a semaphore is a switch that is tested for state, prior to an activity.  If the state is available, the task runs, if the state is not available, the task sleeps until the state becomes available.  The OS usually manages semaphore operation by putting a task in a "sleep" state when a semaphore is not available, and waking the task back up when the state is changed.
    For your case, it could be something as simple as a flag that is examined in the interrupt (SW1 input). If the switch was off, it turns it on, and starts the presentation, if the switch is on, the event is ignored. The presentation routine sets the switch off upon completion.  A "counter" can also be implemented for queued SW1 inputs, so the presentation will repeat if more than one SW1 input is received, so the presentation can loop instead of shutting off.
    Hope this helps,
    Jack
  • mconners
    0 mconners over 10 years ago in reply to jack.chaney56
    I was about to suggest a similar solution. The more unixy way of solving this problem is to use a semaphore.
    gj, jack.chaney56
    Mike
  • brew
    0 brew over 10 years ago in reply to jack.chaney56
    Hi Jack,
    that's the problem at the moment you can double press the button, and the presentation runs twice, any idea how I instigate the semaphore?
    Cheers
    Brew
    0 shabaz over 10 years ago in reply to brew
    Not that I understand Python, but couldn't you check to see if the goshow process is running before calling it again?
    This might help (not tried it): http://stackoverflow.com/questions/6780035/python-how-to-run-ps-cax-grep-something-in-python
  • jack.chaney56
    0 jack.chaney56 over 10 years ago in reply to brew
    Hi James,  If you want to have the presentation not repeat, then ignore the counter component.  Just have a "handshake" flag. The routine that recognizes the SW1 press, checks for an off state to start the presentation and sets the state on. If it is on, it just ignores the press. Upon completion of the presentation, turn the state to off.
    Delayed response behavior, kind of like kids image,
    Jack
  • clem57
    Python has no semaphore flag hence a file system is easy to write and test for. Hint: I have done this before and it works well.
    Clem
  • brew
    This is my code
    #!/usr/bin/python
    import pifacedigitalio
    import subprocess
    pfd = pifacedigitalio.PiFaceDigital()
    pfd.leds[5].turn_on() #Room light ON
    def toggle_led0(event):
      subprocess.call("/home/pi/goshow.sh", shell=True)
    pifacedigital = pifacedigitalio.PiFaceDigital()
    listener = pifacedigitalio.InputEventListener(chip=pifacedigital)
    listener.register(0, pifacedigitalio.IODIR_FALLING_EDGE, toggle_led0)
    listener.activate()
    This is my first foray into this so apologies if it is obvious, sorry i just don't know how to do it.
  • clem57
    0 clem57 over 10 years ago in reply to brew
    Reading and Writing Files in Python all you need. I will return shortly.
    Clem
  • mconners
    0 mconners over 10 years ago in reply to clem57
    Technically, what you are suggesting is a file based semaphore. Although historically these were not recommended due to overhead, this is probably not as concerning these days, but performance should always be a consideration.
    Both python 2 and python 3 have support for semaphores in the threading and or asyncio libraries respectively.
    Mike
