Raspberry Pi Forum inhibit buttons whilst running script?
  • Replies 39 replies
  • Answers 7 answers
  • Subscribers 709 subscribers
  • Views 4772 views
  • python
  • raspberry pi
  • piface
brew
brew over 10 years ago
Hi there I'm trying to use my Raspberry Pi 1B and PiFace to run a little interactive museum exhibition.
Process is Pi is in standby, Standby.py runs from rc.local Relay 1 is closed as this is the main light in the room,
Button Press (SW1) initiates the show
GoShow.py runs, this closes a number of replays which change the lights in the space and trigger a media player for the video the Pi plays a audio file.
I want to inhibit the button when GoShow is active, I've tried to 'de-listen' under the GoShow.py but no luck.
https://github.com/Brewj/Event-Trigger
Anyone any ideas?
Cheers
Brew
  • brew
    0 brew over 10 years ago in reply to mconners
    Hi Mike and all,
    Sadly still no dice
    Exception in thread Thread-1:
    Traceback (most recent call last):
      File "/usr/lib/python2.7/threading.py", line 810, in __bootstrap_inner
        self.run()
      File "/usr/lib/python2.7/threading.py", line 763, in run
        self.__target(*self.__args, **self.__kwargs)
      File "/usr/lib/python2.7/dist-packages/pifacecommon/interrupts.py", line 341, in handle_events
        function(event)
      File "goshow2.py", line 20, in toggle_led0
        listener.deactivate() #Inhibit button
      File "/usr/lib/python2.7/dist-packages/pifacecommon/interrupts.py", line 222, in deactivate
        self.dispatcher.join()
      File "/usr/lib/python2.7/threading.py", line 940, in join
        raise RuntimeError("cannot join current thread")
    RuntimeError: cannot join current thread
  • mconners
    0 mconners over 10 years ago in reply to brew
    In the email that I received a few minutes ago, that had the source attached, I noticed you were missing the two global definitions at the top of the file.
    Between the import statements and the declarations of pfd and listener.
    Did you try that?
    I mocked this code the best I could without having the piface and the libraries available.
    Mike
  • mconners
    0 mconners over 10 years ago in reply to mconners
    Also, in the code that was attached, listener was spelled differently in several places
    Mike
  • brew
    Hi Mike,
    Apologies for that, in my first reply I had missed the definitions, have added them in and corrected the spelling but sadly still no dice.  Thanks for all your time and help though, I really appreciate it.
    If anyone has any inspiration this is where it's at.
    #!/usr/bin/python
    import pifacedigitalio
    import subprocess
    from time import sleep
    import os
    global pfd
    global listener
    pfd = pifacedigitalio.PiFaceDigital()
    listener = pifacedigitalio.InputEventListener(chip=pfd)
    #Standby State
    pfd.leds[0].turn_on() #Room light ON
     #Go Show
    def toggle_led0(event):
      global pfd
      global listener
      pfd.leds[1].turn_on() #On Air and Cabinet ON, Video Go
      sleep (2) #Delay for lights
      pfd.leds[0].turn_off() #Room light OFF
      sleep (1) #Delay before audio
      os.system("aplay /home/pi/wim.wav") #Audio GO
      sleep (3) #End Delay
      sleep (1)
      pfd.leds[1].turn_off() #On Air and Cabinet Off
      listener.activate() #re arm button
    if __name__ == "__main__":
      global listner
      listener.register(0, pifacedigitalio.IODIR_FALLING_EDGE, toggle_led0)
      listener.activate()
    while True:
      pass
    And this is the error I'm getting
    pi@raspberrypi:~ $ python goshow2.py
        self.run()
        function(event)
    There has got to be a way to deactivate / inhibit the buttons surely even if there was just a wait time attached to the deactivate.  I'll keep searching.
    0 shabaz over 10 years ago in reply to brew
    I couldn't follow the entire thread, but generally one trick is to just change the problem if there really is no other easy way out. Not looking into the details of it since I'm worse than useless at Python, and now it looks like the high-level API you're using is spitting out lower-level library related messages, another option would have been to revert to the method mentioned earlier of just checking the process list before calling your player. But your code has changed significantly now.
    Alternatively, if you now want to keep close to the current code you have instead of doing a deactivate, you could change the problem by electrically deactivating the switch. For instance, instead of connecting the switch to 0V, you could connect it to another GPIO pin, which is set to logic low when you want the switch activated, and set to logic high when you want the switch deactivated.
    It is an ugly hack, but it is an option.
  • brew
    0 brew over 10 years ago in reply to shabaz
    Hi Shabaz,
    Thanks for that, I'll attempt your ideas this evening, see how far I get.
    Cheers
    Brew
  • mconners
    One thing, I notice on line 35 of the posted code, listener is spelled wrong, that could make a difference.
    Mike
  • brew
    Hi Mike,
    I did catch that one in the code on the unit.  Still no dice.
  • brew
    Partial success thanks Shabaz, while going though the relay the the button circuit is broken, an acceptable fix but not the ultimate solution.
    Cheers
    Brew
