Raspberry Pi Forum inhibit buttons whilst running script?
  • Replies 39 replies
  • Answers 7 answers
  • Subscribers 709 subscribers
  • Views 4770 views
  • python
  • raspberry pi
  • piface
brew
brew over 10 years ago
Hi there I'm trying to use my Raspberry Pi 1B and PiFace to run a little interactive museum exhibition.
Process is Pi is in standby, Standby.py runs from rc.local Relay 1 is closed as this is the main light in the room,
Button Press (SW1) initiates the show
GoShow.py runs, this closes a number of replays which change the lights in the space and trigger a media player for the video the Pi plays a audio file.
I want to inhibit the button when GoShow is active, I've tried to 'de-listen' under the GoShow.py but no luck.
https://github.com/Brewj/Event-Trigger
Anyone any ideas?
Cheers
Brew
  • brew
    0 brew over 10 years ago in reply to mconners
    Hi, so got it all in had to adjust some of the indents but this is where I'm at
    #!/usr/bin/python
    import pifacedigitalio
    import subprocess
    from time import sleep
    pfd = pifacedigitalio.PiFaceDigital()
    pifacedigital = pifacedigitalio.PiFaceDigital()
    listener = pifacedigitalio.InputEventListener(chip=pifacedigital)
    listener.register(0, pifacedigitalio.IODIR_FALLING_EDGE, toggle_led0)
    listener.activate()
    pfd.leds[5].turn_on() #Room light ON
    def toggle_led0(event):
      listener.deactivate() #Inhibit button
      pfd.leds[1].turn_on() #On Air and Cabinet ON
      sleep (2) #Delay for lights
      pfd.leds[0].turn_off() #Room light OFF
      sleep (1)
      os.system("aplay /home/pi/withy_edit.wav") #Audio GO
      sleep (3) #End Delay
      pfd.leds[0].turn_on() #Room light ON
      sleep (1)
      pfd.leds[1].turn_off()
      listener.activate() #re arm button
    if __name__ == "__main__":
      while True:
      pass
    however I get the following error now
    pi@raspberrypi:~ $ python goshow2.py
    Traceback (most recent call last):
      File "goshow2.py", line 9, in <module>
    NameError: name 'toggle_led0' is not defined
  • mconners
    0 mconners over 10 years ago in reply to brew
    try this
    #!/usr/bin/python
    import subprocess
      sleep (1)
      sleep (1)
      listener.activate()
      while True:
      pass
    you'll probably need to adjust the indent
    Mike
  • mconners
    0 mconners over 10 years ago in reply to mconners
    I think the error was that you were trying to attach the interrupt to an event handler (toggle_led0) before you declared the function, that's why I only said to move the one line
    Mike
  • brew
    Hi Michael thank you for your help, I now get this
      File "goshow2.py", line 7, in <module>
    NameError: name 'pifacedigital' is not defined
    pi@raspberrypi:~ $
  • brew
    0 brew over 10 years ago in reply to brew
    Whops having made the definitions the following
    I get the following error - whoops
    Exception in thread Thread-1:
      File "/usr/lib/python2.7/threading.py", line 810, in __bootstrap_inner
        self.run()
      File "/usr/lib/python2.7/threading.py", line 763, in run
        self.__target(*self.__args, **self.__kwargs)
      File "/usr/lib/python2.7/dist-packages/pifacecommon/interrupts.py", line 341, in handle_events
        function(event)
      File "goshow2.py", line 13, in toggle_led0
      File "/usr/lib/python2.7/dist-packages/pifacecommon/interrupts.py", line 222, in deactivate
        self.dispatcher.join()
      File "/usr/lib/python2.7/threading.py", line 940, in join
        raise RuntimeError("cannot join current thread")
    RuntimeError: cannot join current thread
  • mconners
    Right now you've got 2 objects that are of type PiFaceDigital
    pfd and pifacedigital
    you should probably try to get that to 1, pick one, pfd or pifacedigital and make the appropriate changes to the script
    let's start with that.
    Mike
  • brew
    Thanks for all the pointer, however the plot continues.
    So I have now just got pfd = pifacedigitalio.PiFaceDigital()  however there seems to be a problem with the Listener.deactivate() command in line 3.  If I # comment it and line 23 out the process works fine but if you press the button whilst the script is running it repeats.  This is what I'm trying to prevent.
    If i make line 13 live and run the script the first section starts, the room light comes on.  however if I press the button I get this error.
        self.run()
        function(event)
  • mconners
    Can you post the code in current form?
    Mike
  • brew
    Hi Mike thanks for your help
    goshow.py
    #!/usr/bin/python
    import subprocess
    import os
    listener = pifacedigitalio.InputEventListener(chip=pfd)
    #Standby State
     #Go Show
      pfd.leds[1].turn_on() #On Air and Cabinet ON, Video Go
      sleep (1) #Delay before audio
      os.system("aplay /home/pi/wim.wav") #Audio GO
      sleep (1)
      pfd.leds[1].turn_off() #On Air and Cabinet Off
      #listener.activate() #re arm button
      listener.activate()
    while True:
      pass
    Cheers
    Brew
  • mconners
    I think you are running into a scoping problem, I haven't done a lot of interrupt handling in python, but try this
    #!/usr/bin/python
    import subprocess
    import os
    global pfd
    global listener
    #Standby State
     #Go Show
      global pfd
      global listener
      sleep (1)
      global listener
      listener.activate()
    while True:
      pass
    Mike
