Raspberry Pi Forum make ble device transmit by HW/sw signal only
  • Subscribers 706 subscribers
  • Views 425 views
Hello
I am trying to build a project using BT BLE receiver and transmitter
on the transmitter side, I need it to transmit a beacon about 50 times a second, and only when I tell it to (i.e by a sw write or a hw signal)
is it possible? which BLE module should I use?
Okmi
  • clem57
    0 clem57 over 10 years ago
    I am fairly certain that if the beacon can not directly be turned off, the entire transmitter can. I see you have an answer at https://devzone.nordicsemi.com/question/83280/nrf51822-to-transmit-beacon-upon-user-signal/  by an expert. Please publish your results here since many others may wish to know.
    Good luck with your project btw,
    Clem
  • tonyboubady
    0 tonyboubady over 10 years ago
    Buy any of the modules that support full BLE stack...
    In your case, you have to program both peripheral(transmitter) and central(receiver) ...buy two of the modules with BLE stack... or buy one and use your latest smartphone as central(receiver)...still you have to code both though.
    Code your peripheral(transmitter) to send advertisements and notifications at 20ms timer(50 times a second )...means, your beacon data will send every 20ms interval... of course we can control the notification on press of the button on/off...remember the advertisement of the peripheral(transmitter) keeps connecting and disconnecting according to the notifications/indications, we can start and stop the notifications manually by press of the button or under conditional statements in your coding.
    Advertisements are the signal that sends availability status of the peripheral device to central devices...notifications/indications are the actual data we are sending to central device, which is controllable by manual or timely fashion...
