Raspberry Pi Forum Power Supply Question
  • Replies 21 replies
  • Answers 8 answers
  • Subscribers 708 subscribers
  • Views 4043 views
  • power supply
  • multiple_output
  • raspberry pi 3 model b
finian826
finian826 over 9 years ago
Good day,
Can anyone recommend a good power supply to power 4 or 5 model 3 Pi's? Or can anyone point to a hack with a computer power supply wiring to multiple usb jacks?
Any info would be great. I don't want to run a single power bar for just power bricks for my Pi's.
Terry
  • clem57
    0 clem57 over 9 years ago
    Not sure where you are going with this, but take a look at Raspberry Pi gets a Blade!
    0 dougw over 9 years ago
    Anker 10-Port 60W USB 3.0 Hub can supply 2.4A on each of 3 power ports.
  • rew
    0 rew over 9 years ago
    A "cheap" hack, requiring some "DIY" is to use a standard (small?) ATX powersupply. The "5Vstandby" is enough to power one pi (i.e. silent!), you need to turn the supply on to power more than one. I would personally not hesitate to make a harness that connects to the GPIO pins, so that I can bypass USB cables to be sure that I don't run into bad ones (i.e. having a large resistance).
    On my desk, for testing, I have an ATX powersupply that is "ON", but I have patched the fan to run off 5V instead of the normal 12V. I'm guessing that this reduces the total allowed  power output from the 500W it is rated at to below 100W or so, but it is currently powering two raspberry PIs and a couple of other projects...... (say 5W for the pi's (on average, 10W peak each) and another 5W for the rest....)
    So.... Another option is to do what I did: get that ATX powersupply, and route the 5V through thick cables to a big enough (cheap! (*)) USB hub, and just use the hub to distribute the power.
    (*) The hub needs to be cheap enough that it simply passes on the power instead of being intelligent about it and only delivering the required 0.1A until the client negotiates more....
  • Workshopshed
    0 Workshopshed over 9 years ago in reply to clem57
    The blade powers the Pi through the header pins hence not needing USB connectors.
  • rsc
    0 rsc over 9 years ago
    I've found that my Pi-3 needs about 5.2VDC to operate properly with a WD pi-drive and regular sized keyboard and mouse.
    The supply I built for testing this has an adjustable 5V output. It's a Mean Well RD-50B dual output 5V@4A and 24V@1.4A
    http://www.onlinecomponents.com/mean-well-rd50b.html?p=11952931
    I added a fuse and current meter to monitor what's happening.
    Here's a pic
    Scott
    • Vote Up +7 Vote Down
    0 shabaz over 9 years ago in reply to rsc
    That looks really nice!
    0 DAB over 9 years ago in reply to rsc
    I am planning something similar.
    I have a 200W PC power supply that I plan to modify to run my RPi 3 and peripherals.
    0 balearicdynamics over 9 years ago in reply to rsc
    Until now, the most reliable solution to give a good power to a consistent project (like the modules I am doing for the PiIoT MuZIEum project is using ATx power supplies.
    The only doubt I have is if it is reliable just to shortcut the power pin to make the unit working properly or some kind of circuit should be done, like an emulation of the logic power button on the PC
    Enrico
  • Workshopshed
    0 Workshopshed over 9 years ago in reply to balearicdynamics
    I've used a couple of ATX power supplies like that for running extractor fans in the workshop. So far have proved reliable but are only on for a few hours at a time. I can't see why you would need a special circuit, it is just a signal line that you have to pull low.
    0 balearicdynamics over 9 years ago in reply to Workshopshed
    It is true... I have read somewhere that the. Atx can be damaged just short circuit the power pin to gnd witjout a resistor... Better to solder just a cable image
    Enrico
