Raspberry Pi Forum Why won't this screen work with a Rpi?
  • Subscribers 704 subscribers
  • Views 651 views
coops375
coops375 over 9 years ago
Hi all,
I came across the following screen HDMI+DVI+VGA+Audio Controller Board+12inch 1280*800 DIY TFT Screen For B121EW03 | eBay  which looks like to should accept any HDMI input, such as a raspberry pi.
However, the ebay user states the following when asked: "this board does not support raspberry pi and the input source should be under 1280*800"
I'm confused as to why it wouldn't support a raspberry pi (or any HDMI input) as it looks like a laptop screen with a similar controller board to that mentioned here: How do I use a laptop screen for the raspberry pi?
Dave
  • clem57
    0 clem57 over 9 years ago
    I would take a long look at https://www.raspberrypi.org/forums/viewtopic.php?t=5851 . It could depend on what was tried and how knowledgeable the tester. As to the second link "looks like" is not technically meaningful because LCD standards vary greatly! Google and you can find it very confusing.
  • coops375
    0 coops375 over 9 years ago in reply to clem57
    Thanks for the reply.
    I'm guessing it should work once the config.txt is edited to correspond with the correct resolution in that case.
    I had to do a similar process when using a HDMI to VGA converter, so i'm kind of know what needs to be done.
    I was stressing out as I'd already committed to buying the screen prior to getting the reply from the ebay user.
    It's posted from China so will take ages to arrive but I'll let you know if it works. Worst case I'll use it for something else.
    *note to self buy screen first then build arcade cabinet around it as finding a 12"-13" monitor sucks.
    Ta
    Dave
  • Problemchild
    0 Problemchild over 9 years ago
    David, although you may have some weird incompatibility problem more likely you will find the only mode that the Monitor advertises and supports is 1280x800 native. You can try this on a laptop and see what it thinks are the available modes!
    Any way you can then set up the boot resolution to be the same as one of the supported modes and then you should be good!
    https://www.raspberrypi.org/documentation/configuration/config-txt.md
  • coops375
    0 coops375 over 9 years ago in reply to Problemchild
    Cheers.
    If I fail to get the raspberry pi working I'll hook up an old xbox I have kicking around. I think I already have a component to HDMI converter I should be able to use to make it work.
