Raspberry Pi Forum How to USB boot Raspberry Pi4 ?
  • Subscribers 701 subscribers
  • Views 1766 views
  • usb
  • beta
  • raspberry pi
navadeepganeshu
navadeepganeshu over 6 years ago
I have heard that Raspberry Pi4 can be USB booted or via the network. Also, seen a few posts on people doing it. How exactly can I do it? I tried and it didn't work on a generic procedure.
    0 shabaz over 6 years ago
    Hi Navadeep,
    I think it's experimental, i.e. you may have to experiment and it may not work for all scenarios.
    According to the official documentation:
    https://www.raspberrypi.org/documentation/hardware/raspberrypi/bootmodes/README.md
    It is not supported _yet_ for Pi 4 but will be available at some point.
    However some very recent articles on other sites seem to report some success (and some failures):
    https://www.tomshardware.com/uk/how-to/boot-raspberry-pi-4-usb
    If you can't get it working you may have to sit it out until it is more hardened or better documented (on an official site).
  • aswinvenu
    0 aswinvenu over 6 years ago
    Hi Navadeep,
    Addding to what Shabas has mentioned above.
    RPi USB boot is under beta testing now. But you can still test it out. It's mentioned that It wont work for all MSDs.
    Check it out here: https://www.raspberrypi.org/documentation/hardware/raspberrypi/bcm2711_bootloader_config.md
    About network booting.
    There is a hackaday post on booting RPi4 using PXE (With a bootloader upgrade).
    Check it out here: https://hackaday.com/2019/11/11/network-booting-the-pi-4/
    Hope this helps.
    Aswin
  • colporteur
    0 colporteur over 6 years ago
    NGU, did a recent post where he provided a reference to USB boot that he said worked for him. I don't want to take any of his credit for the post he made in Alsa no audio (glitch) issue Pi 4 fix He provided the following link https://tynick.com/blog/05-22-2020/raspberry-pi-4-boot-from-usb/  I bookmarked the page because it is something I might try.
    0 e14 Contributor over 6 years ago in reply to colporteur
    It worked perfectly with Raspbian for me.  Subsequently, I moved on to Ubuntu 64-bit so I am going to wait for the Ubuntu release to catch up (they have pressure!).  In the meantime, I am keeping the MicroSD installed just for the boot.
    Ubuntu Server 64-bit with the Xubuntu desktop is excellent.  Highly recommended!
  • colporteur
    0 colporteur over 6 years ago in reply to e14 Contributor
    Great follow-up RE. I took note of your post and had hoped you would chime in for NGU and provide some commentary.
  • aswinvenu
    USB Boot for Raspberry Pi is now officially up. New EEPROM binary is available.
    Check this out: https://www.youtube.com/watch?v=8vC3D19e_Ac
    Regards.
    Aswin
