Raspberry Pi Forum Raspberry Pi 2 Not booting
  • Replies 23 replies
  • Answers 2 answers
  • Subscribers 709 subscribers
  • Views 6429 views
  • raspberry
  • pi
  • 2
  • not
  • booting
When I power on the Pi, the HDMI attached monitor shows a screen with shades of various colors and I have no clue where to go from there.  The keyboard is attached to one USB port and the a Wi Pi to another.  Of course the power cable is connected and the SD card (with the OS) is installed.  Ive gone through the Start Up video but the things that are suppose to be happening are not.  This is my first experience with the Raspberry Pi.  But I have years of experience using Microsoft and OS X.  Can someone kindly help this Pi newbie get started?imageimage
  • Gough Lui
    0 Gough Lui over 10 years ago in reply to e14 Contributor
    I'm not quite sure what you are doing here. Most laptops have HDMI output but not HDMI input, so you can't use them as a display for a Raspberry Pi unless the laptop accepts HDMI *input*.
    Secondly, the green power LED on most modern Raspberry Pi (i.e. Model A+ onwards) will turn off if the power supervision chip detects a power dip below a given voltage. This indicates you're not using a power supply that can provide enough current without dropping the voltage *and/or* the cable you are using may not be thick enough (longer cables, and thinner cables - e.g. AWG28 might not be good enough). Sometimes the connectors might not be seating well as well. I would suggest looking at all of this because they are not designed to be powered from regular USB ports, as they draw significantly more power than most USB devices, especially if you have downstream USB devices connected.
    Other members can chime in as well, although next time, you might consider starting your own thread.
    - Gough
  • rew
    0 rew over 10 years ago in reply to e14 Contributor
    Well...  The raspberry pi HDMI connection is an OUTPUT. The laptop has an HDMI OUTPUT as well. Connecting them together is not a good idea. So. I am not surprised that you don't see anything on your laptop screen. The green light flickering could be just fine. So, connect your raspberry pi to a monitor and  have a look what's going on....
    Gough Lui, the power led is RED, the green led is the activity led...
  • Gough Lui
    0 Gough Lui over 10 years ago in reply to rew
    Indeed it is. My bad! I'm interstate at a hotel after a long days' travel, so forgive my confusion.
