Raspberry Pi Forum How to address the UART
  • Subscribers 704 subscribers
  • Views 3184 views
  • raspberry
  • address
  • on
  • pi
  • uart
I've been using the article by Peter Jan " Low level programming the Raspberry Pi in C". this was very helpful and I was able to get his program working to toggle I/O pins. My interest is to use the UART to produce control for DMX512 Lighting. It should be possible top get the required 250 KHz baud rate by setting the clock to 16Mhz. Unfortunately he doesn't give an example program for the uart.  The "data sheet" he uses seems to have a typo in the base address for the UART: 0x7e20100, which is missing one digit. I tried 0x7e201000, but that didn't work. Finding the correct address by trial and error has not been productive, (possibly due to an error in my code?). but it would be helpful to start with the correct address. Anyone know the correct address for the UART?
  • LenReinhart
    0 LenReinhart over 11 years ago
    There is an article on the RPi forum on using bare metal on the Pi2. It looks like the base address changes between the Pi and Pi2. I don't know if that will help. http://www.raspberrypi.org/forums/viewtopic.php?f=72&t=98904&hilit=UART
  • clem57
    0 clem57 over 11 years ago
    https://github.com/Pieter-Jan/PJ_RPI
    Has the code you need!image
    http://www.raspberrypi.org/wp-content/uploads/2012/02/BCM2835-ARM-Peripherals.pdf
    This is the datasheet for the RPi but not the new RPi-2!image On p177 I see incorrect address, but use the names on the sheet and the include from source above and you should be fine!
    Cheers,
    Clem
  • clem57
    For Linux.
    Peripherals base address for older models was 0x20000000, base address for Pi 2 is 0x3F000000. Then add 0x7e20100 to get the correct address for UART registers...
    Probably won't affect you but memory was at bus address offset 0x40000000 for older models, bus address offset is 0xC0000000 for the Pi 2.
    0 e14 Contributor over 11 years ago in reply to clem57
    I've been using that article and looked at the header file, which works with the GPIO pins but there is no reference to the uart.
