Raspberry Pi Forum Questions about Piface Rack
  • Replies 10 replies
  • Answers 2 answers
  • Subscribers 708 subscribers
  • Views 1749 views
micsec
micsec over 11 years ago
Questions about Piface Rack:
My current equipment:
- Raspberry Pi B+
- Piface 2 (40 pins)
- Piface rack (26 pins)
1) can I use my Piface 2 via Piface Rack  (40 pins vs 26 pins)
2) if yes, how to configure SPI jumpers
3) if no, does it existe a Piface Rack 40 pins ?
4) if I use Rack 26 pins, can I use pins number 27 to 40  on Rpi as digital Input/Outut
  • gadget.iom
    0 gadget.iom over 11 years ago
    I haven't seen any sign of a PiRack 2 yet. image
    I can see no issue with using pins 27-40 outside the rack.
  • clem57
    0 clem57 over 11 years ago
    Take a look at this PiFace Shim for a discussion of what to do...
    Clem
  • borrit
    0 borrit over 10 years ago in reply to clem57
    I don't think Michel's question can be assumed answered.  I can understand that the issue of using pins 27-40 on the GPIO header has been answered.
    But I cannot find the answers to the question about different pin counts.
    I too have a 26-pin pirack and 4 piface digital 2's which have 40 pins.
    I cannot stack the piface digital 2s onto the rack because they don't fit - the jumpers get in the way.
    Any suggestions for connection multiple piface 2's (up to 4) to the Pi?
    Thank you
    Joe
  • Robert Peter Oakes
    0 Robert Peter Oakes over 10 years ago in reply to borrit
    I would replace the 40 pin headers with stacking headers (Long ones) and Simpy stack them on each other
    What are you planning on attaching to these ??, if hey ae stacked you wont have easy access to the LEDs or Buttons?
    Oh, another option is to use a ribbon cable with spaced out plugs on it (Similar to an old HDD cable from an old PC)
  • gadget.iom
    0 gadget.iom over 10 years ago in reply to Robert Peter Oakes
    And very easy to assemble with some ribbon cable and IDC plugs. image
    0 Robert Peter Oakes over 10 years ago in reply to gadget.iom
    That's what i'm talking about... image
  • chezdomotix
    0 chezdomotix over 9 years ago
    Hello all,
    I use RPI 2b (40 pins GPIO) + Piface Rack + 2x Piface Digital (first named, same i/o as PFD 2, 26 pins GPIO, fits on the PFRack).
    It works well.
    BUT the Piface Digital seems to be disrupted. Good luck to find them ;-)
    Maybe the customized Raspberry service could do something ?
    0 Robert Peter Oakes over 9 years ago in reply to chezdomotix
    That's because these replace them, extendable, stackable etc, no need for a PI rack. There available from Element14 / Newark / Farnell.
    basically (Electrically ) the same board but more relays and expandable. there is also a motor version.
    PiFace – PiFace Relay Plus
    PiFace Relay Plus stack
  • chezdomotix
    0 chezdomotix over 9 years ago in reply to Robert Peter Oakes
    Yess, thank You Peter :-D , I didn't notice this module, maybe because I'm not using mechanical relays, but SSR instead.
  • clem57
    0 clem57 over 9 years ago in reply to Robert Peter Oakes
    Is that Pi-afull processing?
