Raspberry Pi Forum Key board print on screen
  • Subscribers 687 subscribers
  • Views 497 views
  • b+
  • keyboard
  • input
  • rpi
  • raspberry_pi_getting_started
Recently,I bought the Raspberry Pi B+ and I am using a wireless Keyboard mouse.
The problem is that when I press " with Shiftkey to produce on screen  " i get symbol displayed on screen @.
I also tried to correct by changing config file keyboard info from  gb to US, but no change.
Kindly help how can I correct this.
Regards
Manohar
    Hi. I had the same problem using a wirelsss keyboard. i also tried switching between GB and US English without success. I found a workaround at thetime: use Shift + " on the keyboard to get the @ symbol, and use SHIFT + 2 to get the double quotation mark of ". It's a bit of a pain, but it worked. I ended up going back to a wired keyboard out of frustration so if anyone else has a real solution versus a workaround, I'd appreciate it, too!
  • johnbeetem
    0 johnbeetem over 10 years ago
    This is a long shot, but you might be able to use xmodmap to change the keyboard mapping.  I don't know if the RasPi OS you're using uses the X windows keyboard mapping or something else.
    Anyway, start with man xmodmap and take it from there.
