Raspberry Pi Forum MPS MA732 MagAlpha Angle Sensor Kit with Servo Motor - Industrial Sensing
  • Subscribers 700 subscribers
  • Views 1051 views
  • raspberry pi
JoCl
JoCl over 3 years ago
Hi, I'm interested in this kit " MPS MA732 MagAlpha Sensor Kit with Servo Motor-Industrial Sensing" but can't find it on the Farnell site.
Is it still available or can I order it on another site.
Kind regards
JoCl
    dougw over 3 years ago
    is this it?
    https://canada.newark.com/monolithic-power-systems-mps/tbma732-q-lt-00a/long-eval-board-magnetic-pos-sensor/dp/66AJ8291?st=mps%20ma732%20magalpha%20sensor%20kit
    MPS MA732
  • me_Cris
    me_Cris over 3 years ago
    If this helps, you can search the community for the sensor kit, there are a few blogs posted about it.
  • scottiebabe
    scottiebabe over 3 years ago
    No clue, but I believe this is the kit you are referring to
    /products/roadtest/rt/roadtests/561/mps_magnetic_angle_p#pifragment-4106=9&pifragment-4100=4
    shabaz over 3 years ago
    That's a custom kit. The entire kit isn't one order code, it's actually at least three, which will get you a large subset of it:
    All three of those links are on the right side of the page /products/roadtest/rt/roadtests/561/mps_magnetic_angle_p#pifragment-4106=9&pifragment-4100=4
    Once you have all three of those items, then you'll have the majority of the kit described on that page. However, you may also need a microcontroller board (e.g. Arduino Mega is suggested), and also a RS485 adapter board, which can be MAX485 based if you're using a 5V microcontroller board (like Arduino Mega), such as this one: https://www.waveshare.com/rs485-board-5v.htm  if you find you need programmable control of the motor (I needed that capability).
    Note that you'll also need to create a mount for the MA732, this is not part of the order codes above, plus a magnet (ideally a recommended one! [diametrically magnetised] - see the datasheet). A mount could be 3D printed. It is really dependent on your application, what kind of mount you use.
    99 percent of the information you may need is likely in all the roadtest reviews if not in the datasheet, since it was quite deeply roadtested.
