Raspberry Pi Forum Live stream video software help
  • Subscribers 706 subscribers
  • Views 673 views
blessingspoint
blessingspoint over 8 years ago
Wanting to live stream video to view on the blynk app for a large droid I am Building. What is the best os and software to put on the raspberry pi 3 to be able to do this
    DAB over 8 years ago
    Please supply us with more detail about the source of the video, and your overall system design so we can better assess your question.
  • blessingspoint
    blessingspoint over 8 years ago in reply to DAB
    I am wanting to use a rasp 3 for streaming video that I can access from anywhere  by a ip address  I have the raspberry pi 3 with a camera module  installed.  I have raspin installed  but can change if needed. I have tried tutorial after tutorial and always run into something. A file it can't find ect.. I want to use this an a robot that I have built I am using the app blynk  the rasp won't do anything but video..
    DAB over 8 years ago in reply to blessingspoint
    Have you considered OpenCV?
  • carmelito
    carmelito over 8 years ago
    Here are a couple of options, in addition to OpenCV that DAB suggested above
    -For something very simple try out - mjpg-streamer, this is a quick install and setup .And if blink accepts a URL to create a web-view/iframe then this would be the simplest option, and the URL would be something like - http://RaspberryPiIPAddress:8090/?action=stream
    -For a scenario where you need to capture picture/videos when movement is detected use - motion . This is simpler than using OpenCV but not as powerful as OpenCV. So you will have to choose based on what you are trying to achieve. I wrote a blog post a long time ago which you can find here  Pi Control Hub: Spoke 1 :Security Camera - setting up Motion to stream video
