Raspberry Pi Forum Is there warranty on the Raspberry Pi 3 Model B+ ?
  • Subscribers 705 subscribers
  • Views 2493 views
tkwan98@hotmail.com
tkwan98@hotmail.com over 7 years ago
I purchase the Model B+ last month from Amazon and now when I turn it on, the red light diode comes on but not the adjacent green light diode.
When I connect by ethernet, the ethernet jack light does not come on, so I cannot talk to the motherboard via internet (after installing a micro SD for the o/s).  Everything worked earlier, now it stops for ethernet connection.
Can I return it to element14 for another mother board?
    shabaz over 7 years ago
    Hi Tony,
    The law varies from country to country, but typically if a warranty repair/refund/replacement applies, then you're entitled to send it to the _seller_ of the item (i.e. Amazon in your case, or a seller on Amazon's marketplace). There are statutory warranties (i.e. written into law) that you could check up on - such information is important for all consumer purchases, so worth spending time on getting to know, for your country.
    Also, I wanted to check, have you done any troubleshooting? It would be worth testing with a different network cable, and a different port on the router/switch, or testing the cable and port using a different device. It is normal for the Pi to hang for some time if it thinks nothing is attached to the Ethernet connection. Maybe you've already done this troubleshooting.
    Also, it could be worth downloading and installing Raspbian on another micro SD card too, just in case there is some configuration issue.
  • Gough Lui
    Gough Lui over 7 years ago
    This is the element14 community forums - most of us do not work for element14 so we can't directly advise on warranty issues or returns. For this, you should contact your place of purchase - if you purchased it from Amazon, then Amazon is responsible for customer service and not element14.
    However, the lack of blinking from the activity LED suggests to me either one of two things -
    • That the microSD card may not be properly inserted. Remove the card, check the contacts and then push it back in all the way until it clicks and latches.
    • The microSD card may have become corrupted due to software issues, unsafe power removal, or unstable hardware (overheating/overclocking).
    To rule out the possibility of a corrupted microSD card, I would suggest you download the latest image for the distribution (e.g. Raspbian) you would like to run and write it to the card following the instructions from the Raspberry Pi Foundation. Please follow the instructions carefully, as having an improperly formatted card which is not bootable will result in the same symptoms, and for the most part, Raspberry Pi boards are fairly reliable.
    There is also a slim possibility of a power supply that is very noisy or weak, so perhaps you can try another 5V/2A or above power supply.
    - Gough
    EDIT: shabaz beat me to it.
  • tkwan98@hotmail.com
    tkwan98@hotmail.com over 7 years ago in reply to Gough Lui
    Amazon claims no warranty and defers to element14.  The micro SD is fine - I insert it in another B+ motherboard and it works.  Everything else other than the motherboard works fine with a different B+ motherboard.
    I wasn't sure whether anyone from element14 would answer.
    Thank you both.
  • fmilburn
    fmilburn over 7 years ago in reply to tkwan98@hotmail.com
    You can check out the Amazon return policy:  https://www.amazon.com/gp/help/customer/display.html?ref_=v_sp_return_help&nodeId=15015721
    I have not had problems with returns that came direct from Amazon.  According to the link above, most third part sellers have similar policies but you can check that out.
  • e14phil
    e14phil over 7 years ago
    This would be something you want to return to amazon, BUT it might be something you can fix. If you get one LED but not the other its often that you might have had some problems flashing the operating system to the SD card.
    Make sure you follow the install guide here:
    https://www.raspberrypi.org/documentation/installation/installing-images/README.md
