Raspberry Pi
Raspberry Pi
Documents PiFace Home Timeswitch - turning a light on and off
  • Author Author: PEarle
  • Date Created: 23 May 2013 8:29 PM Date Created
  • Last Updated Last Updated: 8 Oct 2021 5:29 AM
  • Views 5397 views
  • Comments 46 comments
** Update**
I've now implemented this using an Energie Pi Controlled mains Socket - see my blog at Home Automation using ENERGENIE - ENER002-2PI
For details on the Energie socket see ENER002-2PI - ENERGENIE - RF CONTROLLED MAINS SOCKETS, FOR | CPC
One of the things I wanted to do with my Pi from the outset was to be able to use it as a timer, to turn a light on and off at night when I was out, as a simple form of home security. Being something of a newbie when it comes to electronics, my biggest problem was how to wire it up to be able to turn the power on and off.
The Pi relays are rated at a maximum of 20v and 5amps - therefore I cannot connect the Pi directly to the 'mains powered' light !!!
What I am planning on doing is investigating using a to a commercial relay which can cope with the current. When I've done that I shall update this blog again with details of the how the Pi can safely control a mains powered device.
However, the rest of the blog is still valid as it explains how the relay on the PiFace is operated and will be used for the Timer application, when completed.
I've written a java program to control the light switching on and off which does the following;
  • Calculate a random wait time between two values that I have supplied (2 and 20 minutes at the moment)
  • Wait for that period of time to elapse
  • At the end of the wait time, toggle the relay - switch it on if it was already off, and vice-versa.
  • repeat the above ad infinitum
The result is that the light will keep turning on and off in a random pattern making it look as if someone is using the room even when I'm not there !
Java Code
I've already written a document about using Java on the Pi - see http://www.element14.com/community/docs/DOC-54112/l/java-on-the-raspberry-pi. The code that I used for this project is attached to this document (e.g. timeswitch.zip)
Running Automatically
My intention is really to have this as a 'black box' function so that the TimeSwitch application will run as soon as the Pi is switched on. This is accomplished quite easily - all I need to do is write a script to run the java application, and then add it to the initialisation script.
The script to run the java application is as follows ;
cd /opt/pi4j/examples
java -classpath .:classes:/opt/pi4j/lib/'*' com.phe.datetime.TimeSwitch
To run at start up I have edited  /tec/rc.local and added the following line
/opt/pi4j/examples/timeswitch.sh > /opt/pi4j/examples/timeswitch.log
This will execute the java app at start up and also pipe any log messages to timeswitch.log.
timeswitch.zip
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago in reply to Problemchild +2
    Maybe a DANGER rating from Bunny minion through to Skeleton minion
    mcb1 over 12 years ago in reply to michaelkellett +1
    If you look at the RCSwitch there is a RPi solution. Frederick also used these to interface as an I2C device. http://www.element14.com/community/community/design-challenges/forget-me-not/blog/2014/08/11…
    mcb1 over 12 years ago in reply to eatojg +1
    This adds a piece for the RPI and while it suits the UK, there are many others using a similar 433 or 315 MHz RF control. The code in the Watts Clever have a 24 bit data stream, but in reality it only…
  • kidiccurus
    kidiccurus over 12 years ago in reply to Robert Peter Oakes
    Yes, and don't strip to much insulation. I like the idea of a rating system. Perhaps implement it for other things too. Time, cost, difficulty. Someone needs to implement this. Also, what is the weird obsession with minions on this site?
    Maybe a DANGER rating image from Bunny minion through to Skeleton minion
    Robert Peter Oakes over 12 years ago in reply to kidiccurus
    AND Make sure the strain relief Is over the outer insulation, NOT the inner 3 wires, I have seen that so many times
    of course here in Canada and the USA, there are no fuses in the plug or the socket, its all down to the panel and the equipment itself
    and man did it take me some time to get used to Black, White and fortunately Green (Black is Live btw) I grew up in the UK and moved to Canada in my 30's
    Oh, and if you do use a 220V outlet in Canada/USA, the neutral is NOT ground, there is a 110V on each terminal centered around gnd and so both are technically and lethally live image
  • kidiccurus
    kidiccurus over 12 years ago in reply to Problemchild
    Good idea. Its more likely to get noticed than something in the comments.
  • Problemchild
    Problemchild over 12 years ago in reply to mcb1
    Mark this raises my point made to E14 that their should be a mark on such a project to raise caution for any one reading it or that Certain project can "vote" a project "dangerous" or "safety critical" so that readers can use their common sense and realise what they are doing can be dangerous. Mind you if you need to be told it's dangerous then the project probably isnt for you any way !
  • Problemchild
    Problemchild over 12 years ago in reply to Robert Peter Oakes
    Totally agree here, the separation is barely anything and only maintained by wind really.
    to maintain some sort of real physical separation it would be much better to use one of the 100's of relay boards generally marked as for "Arduino" or such then connect the I/O so that they are side by side rather than on top of each other. With regards to the relays I'm sure they can take 10A but I'm sure the board will be cooking well before this image
  • kidiccurus
    kidiccurus over 12 years ago in reply to mcb1
    UK. Looking form the back, Earth(green/yellow) to top, neutral(blue) to right And live(brown) to left via fuse. Make sure they are correctly secured and the correct fuse is used. I make sure someone else checks my work for added safety.
    mcb1 over 12 years ago in reply to kidiccurus
    I can wire a plug
    Are you sure you are doing correctly ?? Just a question. image
    and since your profile gives no continent/country I can't suggest what to look for.
  • kidiccurus
    Good advice, thank you. Also it is not so much brushing up on AC as it is learning basically from scratch. I can wire a plug and that is about it.
    Sorry for wasting your time.
    You aren't wasting my time. image
    I would suggest brushing up on AC and stick to what you know rather than " throwaway comments ".
    The hardest part when you offer advice is being able to support what you say with facts, evidence, or knowledge .... so even warnings about "Don't do this" can catch you out.
    You can always state " I won't do xyz because I don't have sufficient experience/knowledge and consider its dangerous" ... then they can't trip you up.image
