Raspberry Pi
Raspberry Pi
Documents Raspberry Pi 2 Model B 1GB Technical Specifications
  • Author Author: pchan
  • Date Created: 23 Jan 2015 4:01 PM Date Created
  • Last Updated Last Updated: 10 May 2021 7:09 PM
  • Views 39782 views
  • Comments 62 comments
The Raspberry Pi 2 Model B 1GB
6X Faster
Learn More
Buy NowBuy Now
Benefits  image
Technical Specifications  image
Features  image
Benefits:
Get personal with your Pi. Welcome to the Raspberry Piimage 2, the single board computer that thinks it’s a home PC.
Enhanced Quad Core Processor and 1GB RAM now provides you with the opportunity to:
  • Build your own workstation – create and manage your documents and spreadsheets with ease using LibreOfficeimage
  • Faster and more enjoyable gaming – experience less lag and more seamless gaming in all your favourites. Can’t wait to demolish buildings in Minecraftimage, trigger your TNT now and be amazed by the results!
  • No more buffer face – boots up Raspbian in less than half the time as the Model B+
  • More power for your favourite projects – create Space Progammes, Time Lapse Videos, GPS tracking, HD audio and lots more with a full ecosystem of supporting accessories.
  • All your previous Raspberry Pi projects are 100% backward compatible with the new Raspberry Pi 2 Model B 1GB
Technical Specifications:
  • Broadcom BCM2837 Arm7 Quad Core Processor powered Single Board Computer running at 900MHz
  • 1GB RAM
  • 40pin extended GPIO
  • 4 x USB 2 ports
  • 4 pole Stereo output and Composite video port
  • Full size HDMI
  • CSI camera port for connecting the Raspberry Pi camera
  • DSI display port for connecting the Raspberry Pi touch screen display
  • Micro SD port for loading your operating system and storing data
  • Micro USB power source
Raspberry Pi 2 Model B Features:
  • Broadcom BCM2837Arm7 Quad Core Processor powered Single Board Computer running at 900MHz
  • 1GB RAM so you can now run bigger and more powerful applications
  • Identical board layout and footprint as the Model B+, so all cases and 3rd party add-on boards designed for the Model B+ will be fully compatible.
  • Fully HAT compatible
  • 40pin extended GPIO to enhance your “real world” projects. GPIO is 100% compatible with the Model B+ and A+ boards. First 26 pins are identical to the Model A and Model B boards to provide full backward compatibility across all boards.
  • Connect a Raspberry Pi camera and touch screen display (each sold separately)
  • Stream and watch Hi-definition video output at 1080P
  • Micro SD slot for storing information and loading your operating systems.
  • Advanced power management:
  • You can now provide up to 1.2 AMP to the USB port – enabling you to connect more power hungry USB devices directly to the Raspberry PI. (This feature requires a 2Amp micro USB Power Supply)
  • 10/100 Ethernet Port to quickly connect the Raspberry Pi to the Internet
  • Combined 4-pole jack for connecting your stereo audio out and composite video out
  • raspberry
  • broadcom bcm2837
  • the
  • pi
  • 2
  • new
  • b
  • raspberry_pi_space
  • technical
  • 1gb
  • model
  • specifications
  • alnico
    alnico over 11 years ago in reply to e14 Contributor +1
    I moved over 1000 miles from it, unfortunately. Fortunately, I have a buddy that is close and can buy and ship to me cheaper than the element 14 'personal' partner does.
    shabaz over 11 years ago in reply to e14 Contributor +1
    No full schematic is publicly available (it is not open source). But yes, you can directly connect 5V DC to the 40-way connector if you wish to.
    e14 Contributor over 11 years ago in reply to cstanton
    As a developer I have learned that breaking your issue into small modules make it easy to understand. So, to understand better, I am splitting my understanding on "How Raspberry Pi 2 is sold"
    1) Raspberry Pi 2 is available at $35 i.e. Rs.2175.76/- (excluding VAT or any other taxes) as claimed by raspberrypi.org. Since, nothing else is mentioned, so, I believe that this amount is for anyone who want to by the Raspberry Pi 2.
    2) I believe they don't sell this kit directly, so they have given following 3 links if you want to buy Raspberry Pi 2
    Distributor
         http://www.egoman.com.cn/
         http://www.element14.com/
    MERCHANDISE
         http://swag.raspberrypi.org/
    I also believe they mean to say that anyone can buy Raspberry Pi 2 at $35(excluding VAT or any other local taxes) from their distributor/Merchandise.
    3) The link of egoman.com.cn given on raspberry pi site is showing error "ERROR 404 - PAGE NOT FOUND". I also tried to search on their site, but there is no such thing with the name Raspberry Pi.
    4) On element14.com
    element14.com                 : Rs.2900/- : $46
    5) On swag.raspberrypi.org, they are selling "Raspberry Pi 2 Starter Kit" in £75.00 and their is no way, if you just want to buy "Raspberry Pi 2".
    6) So, now back to element14.com. If you want to buy Raspberry Pi 2 from Element14 you have to provide them the Sale Tax Number else element14 want you to go to following resellers
      AND Technologies Pvt (India) - http://www.andtechnologies.in/
      Green India Electronics (India) - http://www.greenindiaelectronics.com/
      Kits'n'Spares (India) - http://shopping.kitsnspares.com/bon1/index.asp
      Remote Computing Tech (India) - http://crazypi.com/
      Tenet Tech (India) - http://tenettech.com/
    7) I was able to find this kit with the following two resellers only.
    greenindiaelectronics : Rs.3,354.90/- : $53.97
    crazypi                       : Rs.3,200.00/- : $51.48
    8)
    I believe we just have to pay CST of 5% in Delhi, India. I can confirm this because I recently (31st Jan 2015) purchase D-link modem from amazon.in and I got a bill with 5% CST and no other Tax.
    9)
    So, if we go by $35 following is the calculation
    - $35 is Rs.2175.76 - lets round it of to Rs.2200/-
    - 5% of 2200 = Rs.110/-
    - So, the total should be Rs.2200/- + Rs.110/- = Rs.2310/-
    - Lets add courier charged of Rs.100/- : Rs.2300/- + Rs.100/- = Rs.2410/- (though I believe courier will not charge more than Rs.50/-)
    - So the final total amount should be somewhere Rs.2410/_
    10)
    How much extra the following are charging
    Element14 : Rs.2900 - Rs.2410 = Rs.490
    Greenindiaelectronics : Rs.3354 - Rs.2410 = Rs.940
    crazypi : Rs.3200 - Rs.2410 = Rs.790
    So, I have the following two questions.
    1) From where I will get RASPBERRY PI 2 in $35.
    2) All the sites which are doing business online are handling sale Tax on purchases done by retail customers. Element14 is the distributor of Raspberry Pi and may other products. Is element14 incapable of handling Sale Tax?
    Feel free to correct, if I am wrong at any place or if any one else wants to correct me, please go ahead.
  • element14jamie
    element14jamie over 11 years ago in reply to e14 Contributor
    Hello sunildatta
    I will reach out to you via direct message for more information.
    Thank you,
    Jamie
  • cstanton
    cstanton over 11 years ago in reply to alnico
    If you can suggest clearer messaging on it then I'm certain that feedback will be taken on-board.
  • cstanton
    cstanton over 11 years ago in reply to e14 Contributor
    Because you're not a company and there are various laws, mainly revolving around tax, that limit the ability to order wholesale from business to business.
    This is why non-business customers are re-directed to resellers.
  • alnico
    alnico over 11 years ago in reply to element14jamie
    If I were in the area of a microcenter.com I would go there, as they have been selling them in stores for the standard price.  I am disappointed in element14's handing of the user/business distinction.
    e14 Contributor over 11 years ago in reply to element14jamie
    Hi Jamie,
    I have already contacted them and they said they need sales tax registration number. Now, my question is how can an Individual/Hobbyist provide sales tax registration number. And to my surprise, a person with a sales tax registration number can place an order for single raspberry pi 2 i.e. qty=1, then why not an Individual/Hobbyist can do the same.
    Regards
    Sunil Datta
  • element14jamie
    Hello sunildatta
    Please contact our call centre on 1800 3000 3888 (Toll free) or +91 080 4000 3888 for further assistance.
    Thank you,
    Jamie
    Jamie
    I think you didn't get my point. I asked "Why an Individual cannot buy raspberry-pi-2 from element14?" I can see the clear difference in price:
    element14                : Rs.2900/-
    greenindiaelectronics : Rs. 3,354.90/-
    crazypi                      : Rs. 3,200.00/-
    Out of the 5 links you have given, only 2 have this kit and as you said "we recommend", so, what I have understood is that as an Individual I can buy this from element14, but I am not aware of the process. It will be great if you can clearly mentioned how can I buy from element14 as an individual.
  • clem57
    clem57 over 11 years ago in reply to clem57
    The same wireless USB works on Raspberry Pi 2 using Rasbian this time.
  • element14jamie
    Hello sunildatta
    It's not that you can't, we recommend going to one of these resellers HERE.
    Thank you,
    Jamie
