RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Wan't to know how to test for trapezoidal wave in TMC9660 using osclloscope
  • Blogs
  • RoadTest Forum
  • RoadTests
  • Reviews
  • Replies 32 replies
  • Subscribers 2659 subscribers
  • Views 1546 views
  • problem
manojroy123
manojroy123 5 months ago
Can someone please share me detail on how to see trapezoidal wave in TMC9660 driver board using osciloscope.
  • beacon_dave
    beacon_dave 5 months ago in reply to manojroy123 +2
    Looks like 'VM is not available' is one of the error conditions that would cause it to light. Another reference to checking the power supply if the error LED glows:
  • jc2048
    jc2048 5 months ago in reply to Jan Cumps +1
    Yes. The schematic shows them connected to GND.
  • jc2048
    jc2048 5 months ago in reply to manojroy123 +1
    I can't help you much with the controller or the motor side of things. You aren't going to see a trapezoidal waveform, whatever you do, because it's a velocity profile you're looking at in the diagram…
  • manojroy123
    0 manojroy123 5 months ago in reply to beacon_dave
    Tried it, still not working. Need someway to set Wizard Pool of the software.
  • beacon_dave
    0 beacon_dave 5 months ago in reply to manojroy123
    What did you try and what did you observe ? You need to be more specific.
    Was the motor power turned on when you initially reported that the error LED was lit when using PARAM mode ?
    If not, does turning the motor power on change the state of the error LED ?
    Do you get a VM voltage reading displayed in the TMCL-IDE ?
    If not did you check if VM was present on the landungsbruecke board ?
    Looks like it appears on pin 1 of the interface connector
    and passes through a voltage divider before being presented to the ADC of the interface microcontroller
    The Wizard Pool should make it easier, otherwise you will need to configure the params/registers manually.
    It's probably not showing though as it looks like you have skipped over the bootloader configuration stage in the user guide.
  • manojroy123
    How to configure bootloader. VM voltage is displayed on the TMCL-IDE
  • beacon_dave
    Is the error LED on the interface board still lit, with a valid VM displayed on the TMCL-IDE ?
  • manojroy123
    Yes. But only when set to param mode in the device setting.
  • beacon_dave
    Ok, that may be due to the 'commutation mode' defaulting to 'system off' after a reset.
    https://community.element14.com/products/roadtest/f/forum/56270/wan-t-to-know-how-to-test-for-trapezoidal-wave-in-tmc9660-using-osclloscope/231276
    Perhaps try sending it a status request like GetVersion or GetInfo using the TMCL protocol and see if you get a sensible response back from it.
    If so, then you can start using param mode commands to configure the motor board and get the motor turning.
  • manojroy123
    How to do that. Which window to open for doing that.
  • beacon_dave
    The Direct Mode dialog you were using before
    https://community.element14.com/products/roadtest/f/forum/56257/most-of-the-problem-with-the-tmcl-ide-4-7-2-is-solved-i-need-help-with-respect-to-starting-the-motor/231124
    The list of params for the TMC9660 is available here:
    https://www.analog.com/media/en/technical-documentation/data-sheets/tmc9660-parameter-mode-reference-manual.pdf
    I'd imagine that the TMCL-IDE is supposed to pre-populate the dialog box instruction list with the TMC9660 param list when you select the eval kit from the list, but if not it looks like you can manually enter them as well.
    There is a demo with an older version here:
    https://youtu.be/wMrv60LYTTw?t=41
    using the direct mode to build into a script. However looks like you can execute single command directly from the direct mode dialog box.
    If you use a status instruction, it should provide a response that will help confirm that you can at least communicate with the TMC9660 via the USB interface in parameter mode using the TMCL protocol.
  • manojroy123
    'Copy to TMCL editor' button is inactive Direct mode dialog
  • manojroy123
