3D Printing
3D Printing
3D Printing Forum Experience with custom 3D-printed Raspberry Pi cases?
  • Replies 8 replies
  • Subscribers 337 subscribers
  • Views 1581 views
  • 3d_printing
lichurbagan
lichurbagan 10 months ago
I want a custom Raspberry Pi case. I found this open-source case design: https://github.com/marceloeatworld/OpenPiCase Has anyone used a service or printed open-source designs themselves? Any tips for modifying designs for Pi 4 or Pi 5?
    dougw 10 months ago +1
    I have a 3D printer and lots of Raspberry Pi modules, but I don't print cases for them. I am worried that the heat from the Pi will cause the printed case to sag. I use metal cases for Raspberry Pi modules…
  • Robert Peter Oakes
    Robert Peter Oakes 10 months ago +1 suggested
    there are plenty of options on printables and thingiverse with or without fans for cooling https://www.thingiverse.com/search?q=pi+4%2C5+case&page=1 https://www.printables.com/search/models?q=pi+4…
    0 dougw 10 months ago
    I have a 3D printer and lots of Raspberry Pi modules, but I don't print cases for them. I am worried that the heat from the Pi will cause the printed case to sag. I use metal cases for Raspberry Pi modules. If you want to use printed cases I would suggest using higher temperature plastic or at least a design that incorporates a good fan solution . There are lots of good looking case designs available on the net, and lots of places that will provide 3D printing services.
  • lichurbagan
    0 lichurbagan 10 months ago in reply to dougw
    Sir, which metal cases do you use? Do you customize them or buy directly from The Pi Hut?
  • embeddedguy
    0 embeddedguy 10 months ago
    If you are comfortable using CAD design tools than you can make your own Pi case all yourself and then use 3D printing service near to you. This way you would get to learn 3D printing. You can use tools such as Fusion-360, Thinker Cad, etc.
    0 dougw 10 months ago in reply to lichurbagan
     Black Box Surprise Prize
     Raspberry Pi 4 Model B Review
    I modify the cases if needed.
  • olivia_49
    0 olivia_49 10 months ago
    I’ve 3D-printed a few open-source Pi cases myself, and it’s pretty straightforward. For Pi 4 or 5, just double-check the ports and mounting holes, you might need to tweak the design a bit to fit perfectly.
    0 DAB 10 months ago
    I have used some enclosures, but I am with Douglas on this one.
    I want as much air around my Pi as I can get.
  • Workshopshed
    0 Workshopshed 10 months ago
    I have used a 3D printed ABS case with a Pi for many years with no issues, would need to check, it is probably a Pi3.
    The 4 and 5 run a lot hotter so you'd want more space for heatsinks and fans along with airvents
    0 Robert Peter Oakes 10 months ago
    https://www.printables.com/search/models?q=pi+4+or+5+case
    over the years I have used many models from both sites without issues, but as already stated, Pi 4 and 5 do need a cooling solution if enclosed so pick wisely
