3D Printing
3D Printing
Files Robox Quick Start Guide
  • Next
  • Previous
  • Author Author: joeman
  • Views 1404 views
  • Downloads 0 downloads
  • Comments 7 comments
This is Robox! Designed to be the simplest, most reliable and comprehensive 3D printing platform available.
  • start
  • quick
  • guide
  • robox
joeman
joeman
  • 23 Jun 2015
  • 0 Downloads
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago in reply to chappy1978 +2
    In quick Order Yes it has a heated bed yes it is in an enclosure yes it can do ABS, PLA, PET and many others no it is not proprietary filament, you can get their reels that have chips for very easy setup…
    Robert Peter Oakes over 11 years ago +1
    I have had mine for a few months now and im currently not so convinced at that statement " This is Robox! Designed to be the simplest, most reliable and comprehensive 3D printing platform available." I…
    Robert Peter Oakes over 10 years ago +1
    so an update on my Robox CEL Printer, it appears I had a faulty power cable *Intermittent connection ) going to the head that ultimately caused the head to overheat and also flickering LEDs , fan stopping…
  • chappy1978
    chappy1978 over 10 years ago
    I would really like to have a chance to see one in person so I could test out how easy they claim it to be. Does it have a heated print bed. Can it print ABS? The other thing that comes to mind are those filaments propriety?
    In quick Order
    no it is not proprietary filament, you can get their reels that have chips for very easy setup or you can use 3rd party ones and set the parameters your self
    yes it is very easy to use yes it will run on its own once the file is uploaded from your pc
    yes it suffers from the same issue as most other printers in that ABS has a tendency to curl on the corners, PLA is way better
    yes it has a 2 year warranty and the folks at Robox are excelent to work with
    How do I know this
    I have had one for a year now and have needed to use the warranty and was very satisfied with the process and outcome
  • chappy1978
    chappy1978 over 10 years ago in reply to Robert Peter Oakes
    That was a quick and straightforward response. Thanks
    your welcome
    your welcome
