3D Printing
3D Printing
Documents Octoprint Relay board
  • Author Author: rctho
  • Date Created: 19 Dec 2017 1:10 AM Date Created
  • Last Updated Last Updated: 6 Oct 2021 9:27 PM
  • Views 3003 views
  • Comments 18 comments
I tested this relay board out on a breadboard. seems to work well. I had to move some components around to scale it down to the size board i had laying around. This is for a remote switch for the 3d printer i got. I'm going to connect it to the gpio pints of the raspberry pi/ octoprint server to shut it down remotely.
I'll test it out on a something else like a light before the printer to ensure i don't fry it. Fingers x'd.
  • octoprint
  • diy pcb
  • relay test
  • 3d printing enhancement
  • 3d print
  • rctho
    rctho over 8 years ago +3
    I finally got this thing up and running and it works great turning the printer on and off. After the breadboard prototype, i had to move stuff around and went a lil' off track from the original design…
  • carmelito
    carmelito over 8 years ago +2
    This is a great idea.Hoping you will post an update, as soon as you have it working with your 3D printer..Thanks
    jw0752 over 8 years ago +2
    Hi Craig, This is a good example of planning and testing prior to building. With this approach you have a much better chance of success. John
  • e14phil
    e14phil over 8 years ago
    Hi Craig
    I love this! I also use OctoPrint.
    What are you using to is trigger relay on and off with the Pi?
    *Edit - Octoprint PSU Plugin. ... Nice.
  • e14phil
    Hi Craig
  • rctho
    rctho over 8 years ago in reply to e14phil
    Hi Phil. I use Octopi. The plugin is available for Octoprint but I think it’s meant to be used for a PSU. An atx type of some sort, but I’m not exactly sure. The plugin settings have a myriad of options. I’m sure it’s in there somewhere or you can check the documentation.
    For the pi I just connected it to a gpio, 3v, and 5v pins which were also in the plugin settings. I just chose the first available. Any one will do.
    I hope that helps.
  • rctho
    Hey Phil,
    You can use gcode commands to turn on/ off your printer instead of gpio pins. I think that's how it works if you're not using octopi. I think i really complicated things with this project cause i probably could have used the gcode too. oh well. Relay boards are pretty versatile. i can apply it to many other projects.
