Artificial Intelligence and Machine Learning
Forum This is how I compare Laplace Conjecture with AI Hype Conjecture
Join Artificial Intelligence and Machine Learning to participate - click to join for free!
  • Replies 14 replies
  • Subscribers 94 subscribers
  • Views 541 views
  • Laplace Conjecture vs AI Conjecture
HKPhysicist
HKPhysicist 3 months ago
  • Laplace Conjecture: If you gave me a long enough rigid stick and a fulcrum, I were able to displace the Earth.
At that time, Laplace's Conjecture was believed to be very true from the viewpoint of mechanical world.
100 years later, his conjecture was disproved by a completely new space-time structure - the relativistic space-time structure rigorously proven by every experiment having been done yet.
  • AI Big Hype Conjecture: If we could get enough processing power (resources, investment and finally, money of course), our data centres and their software would finally turn out to be omnipotent.
However, those AI big hype corps cannot even estimate a formula of their conjecture.
  • "Total Volume of Context Stored represents Intelligence and Skill"
This is another conjecture always boosted by AI Big Hype corps.  Here is how a net buddy responds to the above conjecture (credit to him):
If a land-based continental creature (for instance, a chimpanzee) reads all the swimming tutorials which human have ever authored, does it imply that the chimpanzee could swim as well as the swimming trainers?
  • In the future, there are only 2 sets of people left - one set who knows AI and the other set who doesn't.
The implication of this statement is that - if you do not learn AI and pay money to buy AI services right now, you will belong to the 2nd set - the set of poor people.
This is how I respond to the above statement with these analogies:
  1. After the invention of vehicle driven by combustion engine, people were divided into 2 sets - the one who could drive and another set of people who could not drive.  As we know, professional drivers are usually considered as labours; while some very rich people might even do not need to drive a car.
  2. so many similar analogies.
  • BigG
    BigG 2 months ago in reply to Jan Cumps
    Less is more, so to speak.
    There's one thing that is guaranteed. It will ALWAYS respond to you, no matter what. No silent treatment. No ghosting etc.
    I find that I am starting to use key action words, no matter the task. "Delve/Dive into...", "Expand on this...", "Explore...", "Investigate this problem...", and of course "Proceed with that recommendation/solution/suggestion..."
    DAB 2 months ago in reply to SensoredHacker0
    Yes, I have been playing with it.
    Nothing earth shattering, but it will be some time before I can trust anything generated by AI until it is verified and validated.
    Since no one seems to be interested in verified results, I foresee a lot of bad decisions being made on junk information.
    shabaz 2 months ago
    I've been trying a few things just to see what's possible. got it to do this in one evening.. (a little game that my niece and nephew wanted, their mum wanted no ads or timers like the commercial games). I can't share it since the game is likely copyrighted (I based it on an existing game with cars, just replaced with boats : ) and also contains purchased childrens songs they like, playing in the background, hence I'd be violating some rights if it were distributed. Theyl zip through the puzzles (until they start getting harder), so it is hopefully a fun challenge.
    Jan Cumps 2 months ago in reply to shabaz
    shabaz said:
    11) Write extremely long prompts if necessary,
    I use a different technique (at this moment :Blush) . Have a conversation in short sentences - one-liners. Precise when needed, fuzzy if I don't have an idea myself yet.
    I like that incremental approach.
    (13). If you get an error, just paste in AI and ask what the likely causes (and maybe solutions) are. It's often right.
    Even when its own code throws a compile- or run-time error, pasting that error results in better/working code.
    shabaz 2 months ago in reply to colporteur
    I'm learning as I go, still not sure how optimal I'm being, but I noted some (seemingly/hopefully) plausible suggestions somewhere in an element14 discussion comment but can't remember where.
    Anyway, long story short, it was along these lines (and this is mostly just personal perspective, others will have better ideas I'm sure):
    (1) There is a dichotomy, on the one hand you want to provide decent explanation of your goal and objectives, but on the other hand you also want to split up things so the AI is not overwhelmed with unnecessary detail in parts, so sometimes more than one AI session could be helpful
    (2) If you're coding, then really split up your files (or tell AI how to architect) because otherwise you will find it hard to delve into the results, and AI may make more mistakes later
    (3) Try to speed up the compile/build and the testing, because you will be the slow part of the loop, not the AI. Heavily prefer command-line for all this (get the AI to help make it all command-line driven if you don't have prepared makefiles etc).
    (4) For hardware, consider describing what you want in text, not diagrams or schematics, and don't ask for schematics, but ask for descriptions. I appreciate this might become old-fashioned very quicky, since AI capabilities are improving rapidly
    (5) Ask for tools/libraries/architecture/languages advice from the AI, don't assume that the tools you were planning to use were the best idea. If it suggests a different language or library for instance, then I will strongly consider it for coding even if it means having to learn it slightly first (most languages have the same concepts so this doesn't take long)
    (6) Try to make the AI create tests or stub out things, to reduce the amount of effort when it comes to manual testing. Sometimes the AI will automatically run tests if it can (e.g. I believe Chat GPT will prepare and then run some Python code itself on it's own before providing you with the code) - but AI can go further of course, actually hooking in to real hardware so the user doesn't need to be the tester, the AI can do that and retrieve results from the real testbed, and iteratively improve things with no user interaction.
    (7) I find I get quite good results if I am very specific in describing behavior that is important to my needs, but deliberately give some free reign in other areas where I don't care as much. But see point 8 next.
    (8) Definitely inspect the code, not necessarily for bugs (the AI can identify bugs from described symptoms by itself usually) but to see how things were implemented, and push back for rewrites if it took a lazy approach. With hindsight, you'll see the areas where perhaps one should have been more specific in the request to the AI. For example, if you don't specify a desired data structure, it may use something entirely different. It is important to push back, because otherwise you may end up with code you cannot easily maintain.
    (9) Although AI is excellent at understanding when you're referring to something you have already referred to in a slightly different way in the past, recently I have been trying to be a lot more strict with my terminology. You can make up the terminology as long as it is consistent. For example, if there are a load of items in a system I probably would give them specific names or acronyms and their ports specific names too, and then refer to them consistently.
    (10) This is quite hard, but in general I try to not lock myself down too much, e.g, just because I cannot envisage a need or a scale for something, doesn't mean the code shouldn't be "ready" for it, thus I tell the AI things that might be needed in the future, but not needed now. I don't succeed always, because I get ideas and feature creep temptations later (not as much as an issue with hobby stuff of course).
    (11) Write extremely long prompts if necessary, For instance, it shouldn't be unusual to spend the day just writing the prompt, before even submitting that to the AI. Some prompts can be a dozen pages of one's thoughts/notes, even for hobby projects.
    (12) Ignore 1-11 as necessary : ) All is in flux, and you'll come up with way better guidelines for yourself over time - plus I am sure there are probably good guides elsewhere. I like "Code" magazine, I am learning a lot from that, well worth the subscription for the paper+digital copy.
  • SensoredHacker0
    SensoredHacker0 2 months ago in reply to DAB
    AI has succeeded. the userspace of AI is more of the fad. Im looking at AI as a means to get data. from that perspective, AI has been wildly successful. what if the user wants data about a proprietary thing? lol flag it!
  • SensoredHacker0
    all knowledge, and all knowledge worth knowing aren't even close to the same thing.
    I've been placed on the Tero project. Hey guys, why did we name it that?
    ( because someone in marketing thinks dinosaurs are cool, but wanted to avoid the PT spelling, for something like pterodactyl.  )
    We're really hoping that everyone else wasn't paying attention in Latin classes.
    still we could have looked into the etymology a little more for our heating system flagship product name.
    One way or another, we'll keep you warm!
    I dont think the promise of AI is in having to learn it. The objective from the start was to know you better than you know yourself.
    This little hiccup in the AI timeline where everyone on earth is feeding into the AI landscape is really useful training data, but isnt the real purposed of the thing init?
    Bonus! people will pay to participate! lol.
  • HKPhysicist
    HKPhysicist 2 months ago in reply to manojroy123
    I am glad this article has brought you some happy moment.
    I just concluded some of my and friends' ideas while I browsed youtube videos, news, etc.
    We must express different viewpoints.
  • colporteur
    colporteur 3 months ago in reply to colporteur
    It is not my intention to monopolize the topic but I just found this quote and it is so how I feel.
    "Future shock is the shattering stress and disorientation that we induce in individuals by subjecting them to too much change in too short a time." quote by writer Alvin Toffler. It describes the psychological paralysis, anxiety, and disorientation people experience when the pace of technological and social change outstrips their ability to adapt. They is a picture of me next to this!
  • colporteur
    K, I am more and more becoming a believer that if we do not learn AI we are at a disadvantage. Since joining ChatGPT Plus, I’ve had to confront many personal biases to maximize my effectiveness.
    I refused to upgrade my big-button cell phone until finally it prevented me from doing what I wanted to do. The same for my AI subscription. I had reached a point that no AI or free AI limited, me.
    I have 40 years of learning to apply when I use AI. I find it difficult to direct its actions toward my goals, as it asserts its own will. Microsoft unilaterally determines this approach, removing your choice.
    My quest at the moment is to learn how to talk to AI. If you could follow my problem-solving chats with ChatGPT, you would find the response. STOP: Tell me how to tell you how I want our interaction to occur. Since getting a subscription, I have discovered there are personal settings that i am using more often.
    Learning how to interact with AI appears to be a self-learning exercise. If you find someone willing to share their insight, it can make the interaction more fruitful. I wish I could still have my big button cell phone. That is not reasonable, but then again I liked wooden hockey sticks. You bring one of those into a dressing room today, no one will sit next to you.
    Bt the way. Great topic. I only wish it was with a bunch of folks around a table drinking coffee and trying to solve world hunger.
    P.S. I even used AI to proof this document so these are not my words. No that statement is not true. AI doesn't like my grammar or lack of spelling skills. My grade 10 teacher had the same AI issue.
