Code Exchange
Code Exchange
Blog sensible C++ coding convention - µOS naming standard
Join Code Exchange to participate - click to join for free!
  • Date Created: 1 Sep 2024 6:35 PM Date Created
  • Views 1864 views
  • Comments 7 comments
  • c++23
  • teseo_c++
1 Sep 2024
When writing reusable code, I like to be consistent and use standards. For C++, there are many flavours out there.
I've been looking around for guidance on writing modern C++ code, with templates. That's when I bumped into the µOS naming standards. µOS is a C++ RTOS, maintained by Liviu Ionescu. He 's been very active on this community for a long time, when this forum was used to support the Eclipse Embedded CDT plugin.
He managed to compile a reasonable naming convention set. Pragmatic, not pedantic.
A number of naming proposals try to cover all, or are detailed. I like a standard that handles the conceptual level. To my taste, the µOS standard has a good balance.
It's more brief than many other options out there, but I haven't found a miss. And I like how my code "sounds" when applying the principles.
When writing code, check it out. I've recently designed a C++ library, that (I hope) adheres to that standard. It helps me to stay consistent, and I hope it helps the user to understand my library's API.
that's all :)
Link to related posts.
    DAB over 2 years ago +1
    Thanks Jan. Naming conventions are always a good way to start a fight among software engineers. While most people don't care, they just want to get the code done, you always run into a few fanatics…
  • battlecoder
    battlecoder over 2 years ago +1
    Naming conventions are definitely a fighting ground for a lot of people. I personally think that any naming convention you want to follow is fine, as long as the code doesn't look like you put the ascii…
    shabaz over 2 years ago
    Interesting stuff. I took a peek at the naming conventions you linked to, it makes sense, as well as the Industrial Strength C++ book. My C++ wasn't formally taught (I picked it up initially from an Aussie firm, and then did self-study with books - Stroustrup etc). I stuck with the conventions that firm used, which looks similarish to the Industrial Strength conventions it seems, e.g. capital on the class names, and using an 'm' for member variables, although back-to-front and lower-case, e.g. mPacketCount or whatever. Definitely good to stay consistent in a style.
    Jan Cumps over 2 years ago in reply to shabaz
    one of the appealing things is, that you don' have to use the getter/setter couple (example) int get_id() or void set_id(int). You are advised to write the shorter int id() and void id(int)
    It also has style suggestions for template and enum. Constructs that have evolved since 1997.
    shabaz over 2 years ago in reply to Jan Cumps
    Nice technique. I do the same, e.g. if it were mPacketCounter, then I'd use packetCounter() setter/getter.
    Yes. In the µOS lib (and ISO C++ libs) the private member would be named packet_counter_ , and the access methods would be packet_counter().
    Same principle, different flavour.
