Connector Technology & Design
Forum 40pin LVDS LCD Interface on laptops
  • Subscribers 128 subscribers
  • Views 910 views
I am in the process of designing a prototype which will utilize a ~10" LCD display.
I was wondering if someone out here could help me with one part of this: the 40pin LVDS interface that is common on many laptops and netbooks.
As I understand it, this interface is common accross many LCDs and laptops but I cant quite figure out what it is!
Is it a standard? If so does it have a name? Are there timing diagrams I can look at? Common connectors and pinouts?
I've searched around but so far I can't find any mention of it, only "this product has a standard 40 pin....etc etc"
Searching for information on this is like trying to nail jelly to a wall, or understand what SOAP is/does!
Anyone have experience with this?
    Hi Sebastian,
    JAE is a supplier to Farnell and there Product Manager has sent me your details. Your right finding the right connection for LVDS can be quite a minefield.
    JAE has a great deal of experience within this market and are major suppliers to Compaq, Toshiba, Dell, Fujitsu and are supplying different types of LVDS connections.  In the fist instance I propose you check our website
    www.jae.co.uk and then click on products.  Series you need to possible consider is FI-NX this is a 40 pin using FPC or our  FI-J, FI-JH which is Microcoax cable.
    I hope this helps but please do not hesitate to contact me if you need any further help.
    Best regards
    Pete
    e14 Contributor over 16 years ago in reply to e14 Contributor
    Hello Peter,
    Yes I've used JAE connectors for laptop IDE drives before.
    What I was having trouble with wasn't the connectors so much as the actual interface.
    I have found two interfaces: FPD-Link and OpenLDI (OpenLDI is based on FDP-Link). FDP-Link (Flat Panel Display Link) is apparently used in many laptops to connect the display, but im not sure its what I need since 1. there appears to be some sort of reciever between the LCD 'driver' and the FPD-Link transmitter - maybe FDP-Link is just some interim method to get alot of data through a few cables in the laptop hinge? which brings me on to 2. The term "40 pin LVDS" sounds very specific, FDP-Link does not use 20 data lines, its 5 at most for 24 bit colour:
    http://www.national.com/an/AN/AN-1032.pdf
    I'm pretty sure the connection to which I refer is the same as used on embedded PCs which have LVDS LCD Ports. Apparently these need specific settings in the BIOS for timing purposes but I find it hard to believe that companies would sell LCDs claiming compatability with "90% of laptops" without some sort of standardization.
