Connector Technology & Design
Forum How can i test RS-485
  • Replies 43 replies
  • Subscribers 127 subscribers
  • Views 14219 views
  • connector
  • wiring
  • communication
Dsoky
Dsoky over 3 years ago
Hello, i am looking for a way to test MAX-485 , i do not have any idea how to do it , anyone can help me?
  • beacon_dave
    beacon_dave over 3 years ago in reply to Dsoky +2
    Perhaps Jan Axelson's book 'Serial Port Complete' might help you ? http://janaxelson.com/spc.htm It covers the basics of serial communications, covers working with RS485 networks, and includes some…
  • KennyMillar
    KennyMillar over 3 years ago in reply to Dsoky +2
    Yeah no problem, here it is: https://www.analog.com/media/jp/technical-documentation/data-sheets/1111.pdf If you have any questions please feel free to ask - I use these chips in loads of things. …
  • Dsoky
    Dsoky over 3 years ago in reply to KennyMillar +2
    Ok good stuff i found that module https://handsontec.com/index.php/product/ft232r-usb-to-serialttl-converter-module/ will that work ?
  • Dsoky
    Dsoky over 3 years ago in reply to dougw
    One pc but two ICs right?
  • Dsoky
    Dsoky over 3 years ago in reply to beacon_dave
    good idea but with that way i only tested the transmitting part, i mean i tested the MAX485 as a transmitter , how to test it as a receiver?
  • KennyMillar
    If you want to test RS485, then really you should use THREE or more devices.
    Since RS485 is a multi-drop bus, you'll want to ensure that the data can be transmitted from any one node to every other node successfully.
    One node will becomde the bus driving force by asserting the DE signal on the Max485 and de-asserting it on all the other nodes.
    You can assert the !RE (Receive enable) signal on ALL the nodes, even the transmitting node at any time, even when transmitting. This allows the transmitting node to "read back" it's own transmissions. This is useful for detecting collissions on the bus.
    For example if you send 0xff,0xff,0xff but read back something other than that, you can deduce that there is eithew a) A fault on the bus, or b)some other node transmitted at the same time.
    The bus should be wired point to point, from one node to the next, but not as a "star".
    Appropriate terminating resistors should be used on the nodes at the far extents of the bus, but not on the intermediate nodes.
  • beacon_dave
    In the linked tutorial, one RS485 module is transmitting and one is receiving so you are testing both transmit and receive.
  • KennyMillar
    KennyMillar over 3 years ago in reply to KennyMillar
    I should add...
    Use the appropriate size and guage of wire, connecting all the A's together and all the B's together.
    A common ground is not necessary, since RS485 is a differential signal, however using a common ground can reduce current consumption.
    dougw over 3 years ago in reply to Dsoky
    Yes. It should be possible with 1 pc and 2 ICs.
  • Dsoky
    Any idea about the connections?
  • Dsoky
    Thanks for all that can you please send me a link or pdf for more explamation?
  • Dsoky
    I understand but these are complex steps for testing i hope i find easier solutions without the need of arduino.
  • Dsoky
    Dsoky over 3 years ago in reply to Jan Cumps
    Well having one RS-485 per side is not a problem if that will help, but also what about the connections?
