Embedded and Microcontrollers
Blog PID temperature controller for the EasyL1105 MSPM0 board - Pt. 2: ADC
  • Date Created: 27 Sep 2025 7:46 PM Date Created
  • Views 1392 views
  • Likes 8 likes
  • Comments 14 comments
  • MSPM0L1105
  • MSPM0
  • easyL1105
  • pid
27 Sep 2025
 shabaz designed a development kit for the recent Texas Instruments MSPM0 microcontroller series.
This 4 part blog series documents the steps to design a PID temperature controller. Part 2: add ADC to sample the temperature sensor
(post that introduces the kit)
Goal of this 2nd post
  • add single ADC conversion logic, based on TI adc12_single_conversion
  • use ADC hardware to return value in same Q16 format used in the PID library
Set up ADC SysConfig
The Conversion Data Format, 2s complement, left aligned, happens to be the same Q15 format that our PID library uses.
Code adaption from post 1:
I use a flag to check if sampling is done. The Result Loaded trigger will set that flag.
volatile bool gCheckADC;
uint32_t gAdcResult;
void ADC12_0_INST_IRQHandler(void) {
    switch (DL_ADC12_getPendingInterrupt(ADC12_0_INST)) {
        case DL_ADC12_IIDX_MEM0_RESULT_LOADED:
            gCheckADC = true;
            break;
        default:
            break;
In main(), the IRQ gets enabled
int main(void) {
    SYSCFG_DL_init();
    NVIC_EnableIRQ(ADC12_0_INST_INT_IRQN);
    gCheckADC = false;
The perform_adc() placeholder that I wrote in the 1st post, gets implemented now:
void perform_adc() {
    DL_ADC12_startConversion(ADC12_0_INST);
    while (false == gCheckADC) {
        __WFE();
    gAdcResult = (uint32_t)DL_ADC12_getMemResult(ADC12_0_INST, DL_ADC12_MEM_IDX_0);
    gCheckADC = false;
    DL_ADC12_enableConversions(ADC12_0_INST);
I could make gAdcResult a return value instead of a global variable. Maybe later ...
Thanks for reading. Next, get PWM working.
ccs project for EasyL1105: pid_EasyL1105_20250927.zip
Related posts
    Jan Cumps over 1 year ago
    It's doing something - but not yet regulating.
    PWM controlled by PID, filtered to DC by RC circuit. ADC samples DC and sends it as feedback to PID.
    From the video, it's obvious that my PID is deregulating Slight smile. But that's OK, The test shows that all components are working and communicating.
    shabaz over 1 year ago in reply to Jan Cumps
    That's awesome!!
    That's awesome!!
