Embedded and Microcontrollers
Blog PWM example for the EasyL1105 MSPM0 board
  • Date Created: 29 Sep 2025 7:24 PM Date Created
  • Views 1349 views
  • MSPM0L1105
  • ccs
  • MSPM0
  • easyL1105
  • texas instruments
29 Sep 2025
TI's SDK for the MSPM0 family has a set of examples. They are all targeting one of their LaunchPad dev kits. In this post, I'm porting another one to the EasyL1105.
The example, pwm_led_driver, changes the brightness of an LED by changing the duty cycle of a timer. It's originally written for the LP-MSPM0L1117 LaunchPad. I'm porting it (just like I did in Port an SDK example to the EasyL1105 MSPM0 board). Changes: I removed the not-used GPIO part, and used a timer + channel that can drive pin PA27 - the green LED on the EasyL1105.
What does it do?
The design uses the TIMG1 peripheral, channel 1, to drive PA27 with a PWM signal: That's the green LED. The duty cycle is continuously changing, to create a pulse light effect. Most of the time, the controller is in sleep mode. It does all the work in an interrupt.
The ccs project with source and config files is attached. Thank you for reading.
ccs project adapted to EasyL1105: 5516.pwm_led_driver_EasyL1105.zip
Related posts
    Jan Cumps 28 days ago
    I'm starting development of a stepper motor project. TI has a library for that. Unfortunately, the API documentation link, both in the offline, and downladed Resource Explorer, are not pointing to the correct resource. Online: 404 error, offline: doxygen generated empty documentation.
    Google's AI to the rescue: it found a working version: https://software-dl.ti.com/msp430/esd/MSPM0-SDK/2_00_01_00/docs/chinese/middleware/motor_control_stepper/doxygen/api_guide/html/index.html
    (it also put a rant:
    That is a known, frustrating issue with certain releases of the MSPM0 SDK. TI sometimes packages the Doxygen folder structure with the raw HTML/CSS framework, but misses embedding the actual compiled C-source documentation or links them to an empty index file.
