Embedded and Microcontrollers
Embedded Forum Torque Sensor
  • Replies 15 replies
  • Answers 2 answers
  • Subscribers 503 subscribers
  • Views 2299 views
  • embeded
  • control
  • embedded
  • feedback
  • stepper
  • motor
  • force
Torque Sensor
kas.lewis
kas.lewis over 10 years ago
Hello Element14 Community,
I am trying to find a torque sensor like seen in this non-English video, any help would be greatly appreciated.
Kas
    michaelkellett over 10 years ago +1 suggested
    Are you looking for ready made sensors or are you willing/able to make them yourself. In one of the videos it seemed to me that he was measuring the resistance of tension springs - this would be quite…
    michaelkellett over 10 years ago in reply to shabaz +1
    The torque calibration at motor stall is easy - you need a pulley on the motor shaft and a piece of cotton (for low torques) and a weight. All you need to do is increase the motor current until it can…
    0 michaelkellett over 10 years ago
    In one of the videos it seemed to me that he was measuring the resistance of tension springs - this would be quite tricky to get to work.
    In a different set up he was using  a small load cell.
    I could find 100g ready made load cells on Aliexpress for £4.19 each and lots of different foil strain gauges for under £1 each. To use the load cells you need to be able to do precision machining and to use the raw gauges you need to learn how to stick them on to suitable metal parts (not easy !).
  • screamingtiger
    0 screamingtiger over 10 years ago
    You can buy cheap postal scales on Ebay, and remove the load cells,  They are quality and precise as they have to be.
    The problem is changing torque to linear force or vice versa.
    http://www.dummies.com/how-to/content/how-to-convert-linear-force-to-angular-torque.html
    Curious what you are doing?  image  Care to share?
    0 michaelkellett over 10 years ago in reply to screamingtiger
    What was the cheapest you could find on ebay - I didn't see one for less than £10. The very cheap ones don't always contain a removable load cell.
  • kas.lewis
    0 kas.lewis over 10 years ago in reply to screamingtiger
    Hello screamingtiger,
    I'd be happy to share my project and its goals, for a price... JK. I am working on a custom winding machine. I am looking to make a coil winder that can be setup to do some of the odd windings that are needed where I work and thereby hopefully eliminate the need to go to a third part and convince them to try it and that yes we need it etc. every time we want to test a new setup. If you gyus ar eintrested maybe I can put up more details as i move along the project.
    Kas
  • screamingtiger
    0 screamingtiger over 10 years ago in reply to michaelkellett
    That's about right for buy it now with shipping.  I bid on one and got out half that.  You'll be hard pressed to buy a load cell for that price.  So i guess cheap is subjective.
    As I posted above - you can buy 100g loadcells from Alliexpress for £4.19 each, free shipping.
    That way you get as many as you want with a drawing etc. They won't be very good for that money but probably better than you get in a cheapo postal scale.
    This link is to a slightly different one:
    1pcs strain gauge pressure sensor load cell electronic scale 100g 200g 300g 500g 1kg 2kg 3kg 5kg Range precision weighin…
  • screamingtiger
    I disagree about quality.  Further I'm not sure 100g is enough.  Postal scale will measure Kg.  To the OP.  Is 100g enough?
  • peterjcs23
    0 peterjcs23 over 10 years ago
    One of the tests appeared to demonstrate the resistance of a spring varying under extension and then there were 4 springs in what looked like a bridge arrangement. I just did a quick manual test with a small spring and measured 236mR at rest and 238mR at extension. I'm not sure this could be consistent under all conditions of temperature and loading etc. etc. Not for precision performance perhaps.
    In another scene of the video there were MEMS devices being used. Analog Devoces make MEMS parts MEMS | Analog Devices. These are precision parts that you can integrate into a mechanism to measure torque.
    Can you get a translation of the commentary?
    0 michaelkellett over 10 years ago in reply to peterjcs23
    I measured a spring too (one of a box of 200 tension springs I bought from Aldi years ago !).
    I also detected only a very small change in resistance (once all the coils were separated)  - probably of the order of 0.1 - 0.2% at big extensions.
    No surprise there - metal foil strain gauges typically have a gauge factor of about 2 which means that for 1000ustrain (increase in length of 0.1%) you get a change in R of 0.2%. When a tension spring is stretched the change in strain the metal wire is nothing like as big as the increase in length of the spring so it all fits together.
    Real load cells usually use four gauges in a bridge arranged so that their temperatures will track very closely - the 4 spring bridge would be much worse for this.
    AFAIK none of the major players makes MEMS load cells - the problem is that using large chunks of bulk silicon would be very expensive - a few people have tried making small stick on silicon strain gauges but although you get bigger gauge factors and bigger electrical signals the temperature drift and mis-match to a metal substrate mean that over all they work no better than metal foil.
    Some wide range postal scales (not the ebay for a tenner kind !) use a resonant quartz sensor under tension and can achieve very good dynamic range so that they can do letters with an error of less than 0.5g while still being capable of weighing 20 or 30 kg.
    If the OP only wants to measure/control torque he might do as well by controlling the current in a real DC servo motor (or even a brush-less one but it's much harder to do).
    0 shabaz over 10 years ago
    Hi Kas,
    Another way of doing this (I'm no expert, so this is just an idea in case it meets your needs) might be to connect up a motor to the thing you're measuring, and control the motor supply until you reach the point that the thing starts turning. (I tried this once, see here: BBB - Super-accurate small motor control with a BeagleBone Black ). That would be good for (say) comparisons of torque, or a rough idea of torque, but of course is not calibrated against anything. But, it is repeatable, so could in theory be calibrated first. The torque should be proportional to current, so could be measured with a multimeter. It would be interesting to try this out on several motors (now I think of it, would also make a good physics experiment for schoolkids), to establish a simple reference we can use as a torque measurement device : ) if it was repeatable across different motors (but it might not be - I don't know how precisely motors would match with each other) and if someone had something to calibrate it against.
