Ask an Expert Forum What is the correct replacement?
  • Replies 19 replies
  • Answers 8 answers
  • Subscribers 340 subscribers
  • Views 4397 views
  • thermal switch
  • dehydrator
See a helpful answer?
hafcanadian
hafcanadian over 7 years ago
The thermal fuse on our old Magic Aire II dehydrator failed.  I ordered and installed what appeared to be a correct replacement, and did some soldering to reinforce and repair some connections on the heater board.  All original connections were rivets, so I don't know if solder will survive but am trying to save the device.
Everything seems to work except there's still no heat.  The one bad component yet seems to be a switch of some sort built into the heater circuit.  It is rectangular black, riveted to the board (asbestos(?) ring) with heat bands contacting the rivets, with brass connection arms in between, and a copper tongue inside that may have points on it, it's too hard to see very well inside.  Another dark blade is loose inside and I cannot tell how it fits, nor maneuver it very easily.  The switch is one and a quarter inch long overall and a quarter inch wide.
Is it a thermal switch of some sort, to keep the heater from getting too hot?  Perhaps it's failure caused the thermal fuse to fail?  After the time and effort so far, I'd like to see if I can get a replacement switch and probably a couple new rivets for it, since I'll try to drill out the old ones without destroying the fragile asbestos(?) board.  Or has my resurrection effort all been a waste of time?  There's a lot of extra trays and other accessories we've bought over the years for it... not crazy about tossing it all if I don't have to.  A new one is $120 and just the base unit is $90.
Thanks for any advice.
  • hafcanadian
    hafcanadian over 7 years ago in reply to jw0752 +4 suggested
    Note where I had to notch out the end so it straddled the rivet hole and screw, and add a wide washer for the lower screw to effectively clamp the cutout. This particular device was 2mm shorter than the…
    jw0752 over 7 years ago +3 suggested
    Hi Joel, I could not get your pictures to load. Try replying to your own post and use the picture icon on the tool bar to insert your pictures into the text. In my experience the thermal fuses blow for…
    jw0752 over 7 years ago in reply to hafcanadian +3 suggested
    Hi Joel, The pictured switch is the Auto Setting thermal cut out. It will open up if the element gets too hot due to lack of air flow and automatically close again when it cools down.. It should test with…
  • hafcanadian
    0 hafcanadian over 7 years ago in reply to jw0752
    Thanks for the link, John.  I posted my previous notes before reading your last.  It looks like a likely candidate, and obviously my idea of screws in lieu of messing with rivets was not a bad one.
    Come to think of it, why not clockwise loop the power wire ends and thermal fuse wire ends and tuck them under brass screw heads in the other riveted spots, as opposed to crimp connectors?
    0 jw0752 over 7 years ago in reply to hafcanadian
    Hi Joel,
    ECG/NTE used to sell the proper crimps with the thermal fuses. If you do use a crimp make sure that it is a bare one so you don't get melted plastic. I like your small brass screw approach.  Good Luck.
  • hafcanadian
    Update.
    A big thank you to John for the link.  I received the “thermostat” and installed it tonight, and what to my wondering eyes should happen but... it worked!  At least for the several minutes I had the unit running.  I’m not sure it’ll hold up in the long run and didn’t have the unit totally reassembled, but after an afternoon spent at the hardware store getting the correct screws, nuts, and washers to mount the device with, I was elated to see at least the thing actually working about as it used to.  I’m not sure that it heats up as much, but then it’s not reassembled and enclosed yet, and the “thermostat” didn’t break contact and kept current flowing through the coils.
    In this case I simply used a Dremel to cut off the old thermostat/switch/cutout, leaving the rivets intact.  By using washers to make good contact with the remaining rivet heads and brass ends of the old cutout, I planned to simply use small machine screws, washers, and nuts to clamp down the new cutout.
    The Klixon TH21 I had my eye on had the same dimensions as the original and would’ve fit, whereas this one turned out to be just a little short (ironically, it’s stamped on the back as a Klixon product).  I nipped off the very extreme of one end so it at least straddled the screw hole, inserted a larger washer to span the compromised area, and another washer atop of it appropriate to the screw size;  the “miniature” class screws and such were size #1 (~1/16”) round head a quarter inch long.  I was hoping for brass, but they only had stainless.  Hey, whatever works at this point.  I’m not sure I trust the unit to leave it dehydrating overnight, thermal fuse or not, but at least it can be used while monitored during the day and isn’t a bunch of money in the garbage can.
    If anyone would like to see a photo of the final fix, I’ll be happy to supply it here.
    Much obliged!
    Hi Joel,
    I am very happy that you were able to fix it. I would be glad to see a final fix photo.
  • hafcanadian
    Note where I had to notch out the end so it straddled the rivet hole and screw, and add a wide washer for the lower screw to effectively clamp the cutout.  This particular device was 2mm shorter than the original and the other possible replacement (Klixon TH21), so notching was a way to make it reach and make good contact.
    Strange... after I’d cut off the old cutout I happened to look closely at it, and now it’s contact point is sitting in a normally closed position.  Don’t know what changed just from me removing it, but if it was installed now it would work as designed.  Weird.  Slight lift with a fingernail and the contact disengages the bottom brass, then springs right back like it probably did during an overheat/cool cycle.
    Also on the underside of the old switch was stamped “PEPI M.  42”.  I think that is Portage Electric Products Inc.
    It looks like an excellent job. Hopefully the temperature of the new thermostat will be appropriate.
  • 14rhb
    0 14rhb over 7 years ago in reply to hafcanadian
    Joel,
    Well done (and to jw0752 for helping you) - it is always good to see something repaired rather than get scrapped. Looks like you've made a professional job of it as well.
    Rod
  • hafcanadian
    Regarding John’s valid concern about the heat ultimately degrading the soldered source wire and thermal fuse connections I made, if that happens (if not before) I may just clockwise-loop the wire ends around screws through the rivet holes, imitating my cutout switch fix.  Now that I know what size screw (miniature stainless roundhead #1) to use it seems simpler or at least as easy as using crimp connectors.
    Now I’m off to post my next question for the Community re. where I can get an amber or yellow straw hat LED that’ll operate on a single 1.5v battery... 2v is all I’ve found, and it won’t light up on one AA battery.
    Thanks to John and those that found my question here worth following.
    Joel
    Hi Joel,
    I know there are white LEDs that will operate at or below 1.25 V as they are used in the sidewalk lights that work off of a single 1.25 V NiCad or Nimh battery. Perhaps you can get white ones and coat them the color that you want? The other option is to use a boost  DC to DC converter to get the voltage above the junction energy level for the regular LEDs.
