Ask an Expert Forum Miller DX200 welder SEMIKRON SkiiP 33NEC125T2 Power IGBT Module
  • Replies 97 replies
  • Subscribers 343 subscribers
  • Views 24048 views
See a helpful answer?
mb443
mb443 over 4 years ago
imageThe hot topic for those who owns DX200 welder and willing to participate in re-implementing of the original PowerModule on discrete elements.
This is continuation of the discussion and efforts already put into at other forum:  Miller Boost Circuit Board Assembly NO. 200841
This is a restoration project attempt of reproducing using discreet components an obsolete  power module  which SkiiP 33NEC125T2 no longer produced by SEMIKRON.
DISCLAIMER: This is a high voltage project DANGER. Anyone who joins this experimental project need to be aware of high voltage (up to 1000v) and high currents (up to 100A) which is a high risk and requires to be qualified to work with such circuits and can be done only at your own risk.
  • lanuser
    lanuser over 4 years ago in reply to mb443 +1
    I am no longer interested working on this project. Seems to me besides two people nobody else step forward. I have specially missed one pin on Schematic design, after I ask you to double check my work…
  • alvideo
    alvideo over 4 years ago in reply to alvideo +1
    I redraw module inside wiring like original, exept i added for all IGBT gate resistors. In wiring connectors names are like in module picture (see below). ` Here some more wiring outside…
  • lanuser
    lanuser over 4 years ago in reply to alvideo
    So far seems good.
    Lets wait on  serg200010  on his images.
    Also,  serg200010  has parts on hand, something I do not have at this moment.
  • lanuser
    Also seems D6 & D7 seems wrong polarity
  • alvideo
    alvideo over 4 years ago in reply to lanuser
    It's not mistake. If You look closer, will see, that Q5 swapped  C with E.
  • alvideo
    Wiring with ALL IGBT pin names:
  • lanuser
    All good Thanks.
  • alvideo
    Next stage - need finally decide choose right IGBT. I think, that all IGBT in wiring are ok, except need additional parallel Q1 and Q4 (2x2 IGBT)
    Also i not sure with my choice diodes D1-D5  (VS-E5TX3012-M3). Hyperfast 1200V 30A is enough?
  • lanuser
    For test we need to make sure unit can power on without load.
    1) Take a snapshot / behaver of the unit
    2) Test voltages
    3)  Test heat
    4) Gate voltages
    After that can move on with small load test, while testing unit with load we need monitor heat on IGBT's
  • serg200010
    serg200010 over 4 years ago in reply to lanuser
    C11, C18,D2,R6,Q11
    Q4,Q3,Q1,Q2,Q8Q24,Q25,D19,D20,VR4
    C11,C18
    Q4 - is broken
    it is ok
    it is ok
  • lanuser
    lanuser over 4 years ago in reply to serg200010
    Have you checked if all  leads on Q4 are shorted?
    Also check diode next to Q4
  • serg200010
    I will check and let you know in 2 hours.
