Ask an Expert Forum Miller DX200 welder SEMIKRON SkiiP 33NEC125T2 Power IGBT Module
  • Replies 97 replies
  • Subscribers 343 subscribers
  • Views 24050 views
See a helpful answer?
mb443
mb443 over 4 years ago
imageThe hot topic for those who owns DX200 welder and willing to participate in re-implementing of the original PowerModule on discrete elements.
This is continuation of the discussion and efforts already put into at other forum:  Miller Boost Circuit Board Assembly NO. 200841
This is a restoration project attempt of reproducing using discreet components an obsolete  power module  which SkiiP 33NEC125T2 no longer produced by SEMIKRON.
DISCLAIMER: This is a high voltage project DANGER. Anyone who joins this experimental project need to be aware of high voltage (up to 1000v) and high currents (up to 100A) which is a high risk and requires to be qualified to work with such circuits and can be done only at your own risk.
  • lanuser
    lanuser over 4 years ago in reply to mb443 +1
    I am no longer interested working on this project. Seems to me besides two people nobody else step forward. I have specially missed one pin on Schematic design, after I ask you to double check my work…
  • alvideo
    alvideo over 4 years ago in reply to alvideo +1
    I redraw module inside wiring like original, exept i added for all IGBT gate resistors. In wiring connectors names are like in module picture (see below). ` Here some more wiring outside…
  • lanuser
    lanuser over 4 years ago in reply to serg200010
    Also check this part:
  • serg200010
    serg200010 over 4 years ago in reply to lanuser
    Yes, it is working well. I have installed this IGBT and welder start working like a new))))
  • serg200010
    this IRF640 working well. This board is already fixed. and working. I will take a picture
  • lanuser
    Have you checked Diode on PM?
  • serg200010
    Yes, it is ok
  • lanuser
    So when you will be ready?
    Make sure in power line you put 300W light bulb to prevent damage.
  • mb443
    mb443 over 4 years ago in reply to serg200010
    What IGBT you replaced with the damaged Q4 IGBT on the PowerModule and I'm confused about Mosfet that you mentioned IRF640... where it was replaced?  Did you solder wires to damaged IGBT through side of the PM and placed new one outside somehow? Can we ask you for a picture on how it's done?
    Wondering what happened to C11 C18, are they shorted? or replaced due to high ESR?
    Also, found that's your K25N120H3 should be a great fit instead of a burned IGBT except that they are in TO-247 case, and too large... unless you placed it as an external.
    They are Infinion design full name - IKW25N120H3 w/ 1200v 25A(hot) to 50A(normal), handle up to 100A for short time. And they have an excellent Vce saturation, only 2.05V! So, lot less size radiator is needed for them. Two in parallel would perfectly replace what is needed on a new replacement board.
    www.digikey.com/.../ikw25n120h3.html
    The only problem is a large size of TO-247. If anybody comes across similar but n smaller packaging please share.
  • serg200010
    serg200010 over 4 years ago in reply to mb443
    no, i jst cut wires connected to damaged igbt inside module, please check the picture.
    IRF640  - installed on the main board
  • serg200010
    The welder is working without any problem, I can't load it so much but it is working
  • lanuser
    Just want to confirm with you:
    You are no longer interested to work on the project?
    Or you want to move forward?
    Thanks.
