Ask an Expert Forum Miller DX200 welder SEMIKRON SkiiP 33NEC125T2 Power IGBT Module
  • Replies 97 replies
  • Subscribers 343 subscribers
  • Views 24046 views
See a helpful answer?
mb443
mb443 over 4 years ago
imageThe hot topic for those who owns DX200 welder and willing to participate in re-implementing of the original PowerModule on discrete elements.
This is continuation of the discussion and efforts already put into at other forum:  Miller Boost Circuit Board Assembly NO. 200841
This is a restoration project attempt of reproducing using discreet components an obsolete  power module  which SkiiP 33NEC125T2 no longer produced by SEMIKRON.
DISCLAIMER: This is a high voltage project DANGER. Anyone who joins this experimental project need to be aware of high voltage (up to 1000v) and high currents (up to 100A) which is a high risk and requires to be qualified to work with such circuits and can be done only at your own risk.
  • lanuser
    lanuser over 4 years ago in reply to mb443 +1
    I am no longer interested working on this project. Seems to me besides two people nobody else step forward. I have specially missed one pin on Schematic design, after I ask you to double check my work…
  • alvideo
    alvideo over 4 years ago in reply to alvideo +1
    I redraw module inside wiring like original, exept i added for all IGBT gate resistors. In wiring connectors names are like in module picture (see below). ` Here some more wiring outside…
  • serg200010
    serg200010 over 4 years ago in reply to lanuser
    I have enough K25H120J (30pcs),may be we can use it
  • serg200010
    serg200010 over 4 years ago in reply to serg200010
    K25H1203 - 30pcs
  • serg200010
    The rest of the parts are not a problem.
  • lanuser
    lanuser over 4 years ago in reply to serg200010
    Before moving forward!
    Did you fix the board the one made your Power Module damage?
  • serg200010
    Yes i did. I will share what was broken, tomorrow.
    I have two welder, and two igbt, first igbt working and i fix welder aswell, another welder has a broken igbt and i fixed boards. I have checked all boards they are working. What do i need to do, buy new igbt or making hand-made substitute
  • lanuser
    Understood.
    Can you take some pics of your broken PM?
  • serg200010
    Sure, PM what is that?
    I can take any pictures you need.
    I'll list parts which were broken as well.
  • lanuser
    PM = Power Module
  • serg200010
    Ok np, will do tommorow.
  • alvideo
    alvideo over 4 years ago in reply to lanuser
    What next?
