Ask an Expert Forum Damage detection of roads using piezo sensors
  • Replies 14 replies
  • Subscribers 335 subscribers
  • Views 4076 views
  • research
  • piezoelectric
See a helpful answer?
AniketVis
AniketVis over 3 years ago
I'm working on a project called damage detection in roads using piezoelectric sensor....i need some help and guidance regarding this....
  • scottiebabe
    scottiebabe over 3 years ago +3
    I'm not sure of your location but the search term "smartphone pothole detection" should lead to lots of research papers that might be helpful
  • Gough Lui
    Gough Lui over 3 years ago +3
    There's a mob here that uses accelerometers and cameras mounted to our bus fleet to scan the roads on a nearly continuous basis: https://www.arrb.com.au/news/using-the-sydney-bus-network-to-find-potholes…
    Jan Cumps over 3 years ago in reply to michaelkellett +2
    AniketVis , I can point you to some of the posts that Michael discusses above. They will help you with 3 things: turn the piezo signal into a safe signal, and condition / buffer it (front end) : Piezo…
  • Gough Lui
    https://www.arrb.com.au/news/using-the-sydney-bus-network-to-find-potholes-and-road-issues
    - Gough
    Jan Cumps over 3 years ago in reply to Gough Lui
    That's a smart approach. They measure glitches in bus acceleration, that are typical for road hurdles. That should be a way cleaner signal to analyse than vibrations.
    michaelkellett over 3 years ago in reply to Gough Lui
    I didn't quite specifiy enough when I said:
    (such projects require several skilled PHD+ level engineers with adequate resources in terms of computing and software tools).
    Having access to a fleet of large vehicles repeatedly traversing the same route must help as well !
    Thanks for the link Gough, very useful.
  • phoenixcomm
    phoenixcomm over 3 years ago
    an accelerometer is a way to go if you want something that will give accelerations in 3 dimensions, as your wheel is not moving in one plane, even though that's what it looks like. this is very result oriented, maybe a camera which scans the road, and maybe some LIDAR sensors as well.
