Ask an Expert Forum Oscilloscope issue with MP720115
  • Replies 10 replies
  • Subscribers 336 subscribers
  • Views 3098 views
  • problem
  • oscilloscope
See a helpful answer?
Francois
Francois over 3 years ago
Dear All,
I have an oscilloscope Multicomp MP720115. When I launch it it start normally but after it end with a white screen with the logo of Multicomp Pro.
Is somone already had this issue or could you help me ?
Here is a picture of the issue.
Thanks a lot for your help,
Simon
  • cheetat
    cheetat over 3 years ago in reply to javagoza +3
    Correct.. This oscilloscope is a rebadged unit from UNI-T. Unfortunately there is no firmware upgrade nor factory hard reset that could deal with this problem. I have seen similar issue (stuck on boot…
  • Gough Lui
    Gough Lui over 3 years ago +2
    Perhaps you can try resetting it to factory default. Some units can be reset by pressing and holding a button while powering on. See if the manual has any suggestions, otherwise, it may need to go back…
    Jan Cumps over 3 years ago +1
    I believe there is no firmware upgrade available. If it's still under warranty, I'd contact customer service of the shop you purchased it from.
  • Gough Lui
    Perhaps you can try resetting it to factory default. Some units can be reset by pressing and holding a button while powering on. See if the manual has any suggestions, otherwise, it may need to go back for repair.
    - Gough
    Jan Cumps over 3 years ago in reply to Gough Lui
    The manual suggests to look on the farnell product page. I looked in UK, NZ, Netherlands, Belgium, France, and on the Sinuss reseller shops and couldn't find a download for firmware. The Software is available on several of the sites, but those contain driver, VISA runtime and manual. I could not locate firmware.
    To update your instrument firmware, do the following:
    1. Push the Utility button, select Function in the bottom menu,
    select Configure inthe left menu, select About in the bottom menu.
    View the model and the currently installed firmware version.
    2. From a PC, visit the Farnell product web page and check if the website offers
    a newer firmware version. Download the firmware file.
    The file name must be*.update.
    The file name can be up to 15 characters long (including the suffix).
  • javagoza
    javagoza over 3 years ago
    Maybe this one from UNI-T is similar
    https://instruments.uni-trend.com/EU-EN/digitaloscilloscopes/upo2000e.html
    Jan Cumps over 3 years ago in reply to javagoza
    It looks like it's the same :-. I was looking on the OWON site if I could find a brother, and didn't see one there.
    Unfortunately, also only VISA and USB software available. No firmware upgrade.
  • Francois
    Thanks a lot for your answer and the time you tooked in order to help me. Indded it look like a bug in boot sequence. I also tried to find a firmware upgrade but nothing on Farnell website. As I bought it from Farnell I sent them a mail. I ll let you know the answer. Thanks
    dougw over 3 years ago
    Check with Saelig / Owon
    https://www.saelig.com/supplier/owon/xds3000-series-user-manual_saelig.pdf
  • kmikemoo
    kmikemoo over 3 years ago
    I'm a bit late to the fight here.  I had something similar on a portable oscilloscope and it wound up being a power supply problem - specifically the LiPo battery had died.  If it's not within warranty, it's a direction.  Good luck.
  • cstanton
    cstanton over 3 years ago
    You can contact the technical support here. We should also have a couple of tech' support on the site, TanCheeTat / cheetat  and Prasanth Arockiaraj if they're currently active.
  • cheetat
    Correct.. This oscilloscope is a rebadged unit from UNI-T. Unfortunately there is no firmware upgrade nor factory hard reset that could deal with this problem. I have seen similar issue (stuck on boot loading screen on other brands before) and the only resolution is to sent back for warranty repair. I believe Francois maybe very unfortunately to have owned this unit and he should seek Farnell customer service for return for warranty claim for such units if it is still under warranty
