Ask an Expert Forum Piezo
  • Replies 9 replies
  • Subscribers 325 subscribers
  • Views 1996 views
  • ask_an_expert
See a helpful answer?
Piezo
zafranzri
zafranzri over 2 years ago
Hello, everyone.
Is this thing is electric generated and authentic? And if do, can you explain me more about this thing for my science project? Thank you.
    Jan Cumps over 2 years ago in reply to beacon_dave +3
    The Zener circuit doesn't fully protect against higher impact events The Predictive Maintenance Tale - piezo element voltages
  • beacon_dave
    beacon_dave over 2 years ago +2
    https://www.dfrobot.com/product-399.html Buffer circuit Piezo Disk datasheet https://github.com/Arduinolibrary/DFRobot_Piezo_Disk_Vibration_Sensor/blob/master/datasheet.pdf?raw=true Wiki …
    dougw over 2 years ago +2
    Here is a demo... Tis The Season For Arduino
  • anniel747
    anniel747 over 2 years ago
    If it's on e14 it should be authentic.
  • zafranzri
    zafranzri over 2 years ago in reply to anniel747
    Thank you for your response! But.. can you explain what is e14? I don't understand..
  • beacon_dave
    Buffer circuit
    Wiki
    https://wiki.dfrobot.com/Analog_Piezo_Disk_Vibration_Sensor__SKU_DFR0052_
  • anniel747
    anniel747 over 2 years ago in reply to zafranzri
  • robogary
    robogary over 2 years ago
    Interesting you found a blog on E14.  It looks to be a neat sensor, I'll have to try it sometime.
    It is available for order at Newark Electronics  https://www.newark.com/dfrobot/dfr0052/piezo-disk-vibration-sensor-gravity/dp/52AJ4985
    or directly at DFRobot https://www.dfrobot.com/product-399.html
    and other sales outlets.
    DFRobot provides a description of its behavior.
    INTRODUCTION
    The DFRobot Vibration Sensor buffers a piezoelectric transducer that responds to strain changes by generating a measurable output voltage change which is propotional with the strength of vibration. So you can know the extent of vibration. Different from digital vibration sensor that only accounts times, this analog one can tell extent of vabiration.
    You didnt specificy what your science project was, so its unclear what information is needed.
    Good luck with your project.
    Here is a demo...
  • bidrohini
    bidrohini over 2 years ago
    Dfrobot sells authentic products as far as I know. Here are the details along with sample code: wiki.dfrobot.com/Analog_Piezo_Disk_Vibration_Sensor__SKU_DFR0052_
  • cstanton
    cstanton over 2 years ago
    Halo zafranzri , Saya tidak yakin saya memahami sepenuhnya pertanyaan Anda. Anda telah menemukan sebuah produk di toko online element14 Malaysia. Apa dan mengapa Anda tertarik pada produk ini, dan dengan tepat apa bantuan yang Anda butuhkan terkait produk tersebut?
