Ask an Expert Forum Help Testing Relay
  • Replies 20 replies
  • Subscribers 321 subscribers
  • Views 4568 views
See a helpful answer?
Help Testing Relay
HBPhillie
HBPhillie over 2 years ago
I would like to replace what I think is a faulty relay on my jacuzzi board... but there are 4 P&B T92S7D12-12 Relays on this board... My question(s)
How do I test these .. the Jacuzzi J330 is powered by 220 VAC.  Do I need to remove them?
I have some Engineering degrees but not much electronics experience.  I think I see that these are double pole and I might need to power the 'input' side and read the switching sides?  If this sounds like I'm not sure how to do this you're reading correctly.  I've actually already replaced the board but I want to see if I can diagnose the problem with the old one.
Thank you for any help.
Tom
    dougw over 2 years ago +2
    https://www.te.com/commerce/DocumentDelivery/DDEController?Action=srchrtrv&DocNm=1308242_T92&DocType=DS&DocLang=English You can see from the datasheet these operate from 12 Vdc across the coil. You…
    dougw over 2 years ago in reply to HBPhillie +2
    Try some resistance measurements before removing components (with the card disconnected from power). It may tell you a lot with a lot less work.
  • kmikemoo
    kmikemoo over 2 years ago in reply to HBPhillie +2
    Good plan. Resistance testing on the PCB is usually complicated by the snubber diodes across the coils. I default to the Goesinta/Goesouta test. If the circuit provides power to the relay but the contacts…
  • phoenixcomm
    0 phoenixcomm over 2 years ago
     HBPhillie  I don't know which one you have but that relay comes in two formats, one mounts through-hole (soldered), and the other is spade terminals maybe plugged into a socket.
    If you are lucky and they are socketed you can always swap them. start at 1 swap it with 2, test, no swap to original. then swap 1 with 3, and the beet goes on. ~!~ Good Luck Cris
  • phoenixcomm
    0 phoenixcomm over 2 years ago in reply to anniel747
     anniel747 imageI have been doing this for a looong time! I hate clamp-on ammeters they are dangerous! This is my go-to tool. Fully insulated and works with the wire in the slot! NO TOUCHING NOTHING! ~~ Cris
  • colporteur
    0 colporteur over 2 years ago in reply to phoenixcomm
    I saw the relay post and wondered when you might respond. Your years in the industry have given you more exposure than most in the field of relays.
  • anniel747
    0 anniel747 over 2 years ago in reply to phoenixcomm
    [deleted]
  • HBPhillie
    0 HBPhillie over 2 years ago in reply to anniel747
    Sorry, it's taking me a bit of time to parse all the information here... For example a reference to the Data Sheet takes me a hour or more to try and translate all the info on the it.. and I'm still not sure what it says or what applies to my relay ??  Oh well this is a process.  In any case the REV on my board is 'REV. 3.56'. I've read where they have moved on from this but this is my original board.  Thanks for your time.
  • HBPhillie
    Correct, they are soldered.
  • anniel747
    0 anniel747 over 2 years ago in reply to HBPhillie
  • phoenixcomm
     anniel747  HBPhillie Hey life is not fair then you are stuck!! The world sometimes gives you onions!!  too bad, now you have to turn them all on and measure the standing voltage across the relay coils when the unit is ON. vs resistance when OFF,  you are looking for one coil that is out of range. according to the datasheet, a 12v coil has a resistance of 86 ohms. you are looking for one coil that is out of range or open.
  • HBPhillie
    0 HBPhillie over 2 years ago in reply to phoenixcomm
    Thank you.  When you look at the data sheet my coil appears to be the one on the right... there are 2 pins on the one right, one left... at the other end are 2 sets of 2 pins each (total or 4 pins) ... I say 'pins' but each pin has 2 solder points so a total of 6 pins each with 2 points projecting thru the board to be soldered.  I know this doesn't sound very 'technical' but I don't know the correct terminology .   I know that if I understand which pin is which... I can unsolder these (unless I can test them on the board), I can rig up a 12 volt power supply and I can read the resistance at the switch ends.  what I'm missing is an understanding of which pin is which.
    Thank you. Tom
  • kmikemoo
    0 kmikemoo over 2 years ago in reply to HBPhillie
    If you cannot do a voltage check on the relays in place, I'm going to encourage that you remove the relays from the PCB to bench test them.  I have released the magic smoke by trying to power stuff in place.  Some things don't like to be backfed.  The unlabeled pins on the graphic are your contacts.
