FPGA
FPGA
Forum Problems with HLS Vivado Run C simulation
  • Subscribers 582 subscribers
  • Views 2102 views
bdiouiska
bdiouiska over 6 years ago
I hope this is in the right Topic.
Hello I am an engineer student and currently I am doing my final studies project , but i encounter some problems using vivado HLS , I hope that you can help me and thanks ,
I am going to show you my algorithm by the end of the message,
First my first problem is after i add file in Top Function (my main C file), the next step is Test bench files , I don't know what to put ??? I only have one algorithm, And this makes the Run C simulation not going in fact i got this message "cannot build design unless a test bunch with function main() is defined"
I tried to put my algorithm in both (top function same in test bench files) but i encounter some problems . My final goal is do verification synthesis and finally optimisation . I thank you for your help.
Here my algorithm in C.
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#include <math.h>
#include <string.h>
int main()
int n1,n2,n3,i,j,k;
    float nu,a,b;
    a=0.25;
    b=0.5;
    nu=0.6; //donnée
    scanf("%i",&n1);
        scanf("%i",&n2);
    scanf("%i",&n3);
     float X[n1],W[n1][n2],W1[n2][n3],E[n2],Y[n2],E1[n3],Y1[n3],Deltaj[n2],Deltak[n3],Sd[n3],es[n3],Wa[n1][n2],Wa1[n2][n3];
for (i=0;i<n1;i++){
    scanf("%f",&X[i]);
for (i=0;i<n3;i++){
    scanf("%f",&Sd[i]);
// ici j'ai pas su comment calculer es[k] qui est egale es[k] = Sd[k]-Sc[k]; Sc[k] commont la calculer ??
for (i=0;i<n3;i++){
    scanf("%f",&es[i]);
for (i=0;i<n1;i++){
    for (j=0;j<n2;j++){
            W[i][j]= (rand()) / (RAND_MAX + 1.0);
for (i=0;i<n2;i++){
    for (j=0;j<n3;j++){
            W1[i][j]= (rand()) / (RAND_MAX + 1.0);
 float Somme1 (int n1,int i,int j,float X[n1],float W[n1][n2])
int h;
float Somme=0;
for (h=i;h<n1;h++)
Somme += (X[h]*W[h][j]);
return (Somme);
float Somme2 (int n3,int j , float es[n3] , float W1[n2][n3])
int h;
float Somme=0;
for (h=0 ; h<n3;h++)
Somme += es[h]*W1[j][h];
return(Somme);
//Fonction globale(1)
for (j=0;j<n2;j++)
for (i=0;i<n1;i++)
E[j]=Somme1(n1,i,j,X,W);
Y[j]=b+a*E[j];
Deltaj[j]=Y[j]*(1-Y[j])*Somme2(n3,j,es,W1);
Wa[i][j]=W[i][j]+nu*Deltaj[j]*X[i];
// Fonction 2
for (k=0;k<n3;k++)
for (j=0;j<n2;j++)
E1[k]=Somme1(n2,j,k,Y,W1);
Y1[k]=b+a*E1[k];
Deltak[k]=Y1[k]*(1-Y1[k])*(Sd[k]-Y1[k]);
Wa1[j][k]=W1[j][k]+nu*Deltaj[j]*Y1[k];
return 0;
  • bartokon
    bartokon over 6 years ago
    I don't remember but there are like 2 places where you can put files -Test Bench and the other one image
    Make those files:
    Main_tb.cpp with:
    #include "myFunction.h"
    int main()
    //Call function make some operations and typical dynamic programming
    //compare results with accelerated function
         int a, b, c;
         a = 1;
         b = 2;
         myDoSomethingInHardwareOne(a, b, c);
         if(c)
              myDoSomethingInHardwareTwo(a,  b, c);
    in the other one (synthesis function location this is one row above TestBench):
    myFunction.h:
    void myDoSomethingInHardwareOne(int a, int b, int c);
    void myDoSomethingInHardwareTwo(int a, int b, int c);
    and myFunction.cpp:
    void myDoSomethingInHardwareOne(int a, int b, int c){c = a*b;};
    void myDoSomethingInHardwareTwo(int a, int b, int c){c = a-b;};
    If you are making cosim also include myFunction.h and myFunction.cpp to Main_tb.cpp catalog/row because without it cosim wouldn't work for me.
  • bdiouiska
    bdiouiska over 6 years ago in reply to bartokon
    Thanks for your answer , though I've got this problem do you have any idea about it ?
    ../../../../Desktop/PFE/C/Untitled2.c:69:63: error: expected ';' at end of declaration
  • bartokon
    bartokon over 6 years ago in reply to bdiouiska
    You should watch some courses on C/Cpp. I see that you don't understand global functions and their definitions and proper locations....
    Rewrite your code in Python like style because its easier to see where you are missing "};" look how I have written int main() you can see all the nesting functions and those " { };" marks.
    Good luck!
  • bdiouiska
    ok thank you for your answer
