FPGA
FPGA
Forum 在用Spartan6生成的Clock时在maping遇到的问题
  • Subscribers 581 subscribers
  • Views 1053 views
  • clock
  • hdmi
  • mapping
Flush
Flush over 15 years ago
最近在做Spartan6上的视频输出,输出的接口是HDMI接口,要求格式是720P。
系统的时钟主要有
1. 750M(TMDS输出的IO输出时钟,必须接bufpll)
2. 75M(720P的像素时钟)
3. 150M
4. 100M (系统时钟)
5. 24M (外围设备需要的时钟)
工具是ISE12.2
然后通过ISE自带的Clock_wizard来生成需要的时钟,750M是专门用来做TMDS的IO输出时钟,主要端口定义如下:
--Clock_gen是通过Clock_wizard自动生成的。
Clock_gen_inst : clock_gen
port map(
CLK_IN1 => sys_clk_in,
RESET => sys_rst,
LOCKED => LOCKED,
CLK_OUT1 => pix_clkx10_pll, --750M, need bufpll as buffer
CLK_OUT2 => pix_clk_pll, --75M
CLK_OUT3 => pix_clkx2_pll, --150M
CLK_OUT4 => sys_clk, --93.75M
CLK_OUT5 => external_clk_buf );
而pix_clkx10_pll必须添加bufpll
BUFPLL #(
.DIVIDE(5)
tx_bufpll_inst(
.IOCLK(tx_clkx10),
.LOCKED(LOCKED),
.LOCK(LOCK),
.PLLIN(pix_clkx10),
.GCLK(pix_clkx2),
.SERDESSTROBE(tx_serdesstrobe));
按照上面的时钟定义在mapping的时候出现这样的error:
ROR:Place - ConstraintResolved NO placeable site for U2/tx_bufpll_inst
ERROR:Place - SIO has over-constrained componet U2/tx_bufpll_inst to have to placeable sites. Constraints come from
driver constraints AND load IO constraints
Phase 4.2 Initial Placement for Architecture Specific Features (Checksum:fc8413ca) REAL time: 38 secs
Total REAL time to Placer completion: 38 secs
Total CPU time to Placer completion: 38 secs
ERROR:Pack:1654 - The timing-driven placement phase encountered an error.
Mapping completed.
See MAP report file "hdmi_top_map.mrp" for details.
Problem encountered during the packing phase.
通过添加PLL或者删除其中一个clock,尝试了很多次还是报错。在网上找了,找到了类似的情况,但是没有给出解决方案来。
后来尝试添加约束才搞定的。直接指定bufpll的物理位置:
INST hdmi_encoder_0/hdmi_encoder_0/tx_bufpll_inst LOC= BUFPLL_X1Y5;
估计原因是:bufpll和OSERDES因为不在一个bank下导致无法进行mapping。见图1.
图1. 使用OSEREDS的原理图
