FPGA
FPGA
Forum is there a step by set video on Mojo V3 FPGA?
  • Replies 8 replies
  • Subscribers 582 subscribers
  • Views 1422 views
  • frontpage
I can't even get stated
  • clem57
    clem57 over 10 years ago
    Yes, see https://embeddedmicro.com/tutorials/mojo/
    e14 Contributor over 10 years ago in reply to clem57
    That is my problem the only video is "What is an FPGA?"
    When I follow the written Instructions on that website I get  the error "Mojo did not respond! Make sure the port is correct."
    I asked how do solve this problem on the emdeddedmicro forum and if it ever gets approved someone may see it.
    I am looking for the xilinx Mojo3 version of this video:
    https://www.youtube.com/watch?v=BAPTvdrb9dw
  • clem57
    clem57 over 10 years ago in reply to e14 Contributor
    Maybe this is a clue: https://embeddedmicro.com/forum/viewtopic.php?t=707
  • clem57
    If video a must https://www.youtube.com/results?search_query=mojo+fpga+tutorial
    Thank you for the quick response unfortunately they marked the problem as [solved] when It really is NOT wasn't I am running window 7 64bit.
    It looks like the last step in xilinx to get the program to the board is an outside board specific software? I just see a million points of failure with this approach with no support if that company goes under. so every tutorial has a different way of doing that last step that only works for that board
  • clem57
    Is this your first foray into FPGA? Why did you pick Mojo? What project plan do you have if any?
    Clem
    Clem,
    I got the CPLD from https://www.youtube.com/watch?v=BAPTvdrb9dw  and I was able to get that Altera board to work. I got the Mojo because I am building a computer from first principals and I need more IO pins.
    I want to do a hardware version of Nand 2 Tetris The Elements of Computing Systems / Nisan & Schocken
    David
