FPGA
FPGA
Forum altera max II FPGA PLEASE HELP!!!!
  • Replies 12 replies
  • Answers 3 answers
  • Subscribers 585 subscribers
  • Views 4767 views
rgiguere
rgiguere over 8 years ago
OK so im just getting into FPGA and PLCD  and i ordered a Altera(now intel) MAXII FPGA it came with a usb blaster ribbon cable and usb download cable the problem Im having is it seems the drivers for the usb blaster dont seem to work with windows 10 it keeps saying there is a problem with the driver a bad hash which seems to be a problem with the digital signature the problem is i cant find a single usb blaster driver for the altera that works with winows 10 does anyone have any ideas? By the way Intel tech support was no help they have absolutely no idea and from what I researched every one on windows 10 has the same problem.
  • Gough Lui
    Gough Lui over 8 years ago +3 suggested
    It may well be possible that no signed drivers exist for Windows 10. You may be able to get around it by disabling signed driver enforcement - do a search for this and you will find a few hints on how…
    genebren over 8 years ago +3 suggested
    Robert, I found this site, which describes the driver installation procedure (including Windows 10). The instructions make it sound like the USB blaster driver is a part of the Quartus II installation…
  • andywest
    andywest over 8 years ago in reply to Gough Lui +3 suggested
    I can confirm that it was necessary to disable signed driver enforcement when I installed on Windows 10. It did work after that.
    0 michaelkellett over 8 years ago in reply to rgiguere
    Just reminding you that the Maximator has a different FPGA - I'm sure you noticed really.
    It's a nice modern MAX10 and I've found them pretty good.
  • rgiguere
    0 rgiguere over 8 years ago in reply to michaelkellett
    Thank you again from what i read it seems like it would be a good fit for someone that is just learning about fpga and verilog which is what i really need. Im hopping that the transition from programming Raspberry PI and Arduino will help some but from what i can tell fpga is almost its own style all together
