FPGA
FPGA
Forum altera max II FPGA PLEASE HELP!!!!
  • Replies 12 replies
  • Answers 3 answers
  • Subscribers 585 subscribers
  • Views 4721 views
rgiguere
rgiguere over 8 years ago
OK so im just getting into FPGA and PLCD  and i ordered a Altera(now intel) MAXII FPGA it came with a usb blaster ribbon cable and usb download cable the problem Im having is it seems the drivers for the usb blaster dont seem to work with windows 10 it keeps saying there is a problem with the driver a bad hash which seems to be a problem with the digital signature the problem is i cant find a single usb blaster driver for the altera that works with winows 10 does anyone have any ideas? By the way Intel tech support was no help they have absolutely no idea and from what I researched every one on windows 10 has the same problem.
  • Gough Lui
    Gough Lui over 8 years ago +3 suggested
    It may well be possible that no signed drivers exist for Windows 10. You may be able to get around it by disabling signed driver enforcement - do a search for this and you will find a few hints on how…
    genebren over 8 years ago +3 suggested
    Robert, I found this site, which describes the driver installation procedure (including Windows 10). The instructions make it sound like the USB blaster driver is a part of the Quartus II installation…
  • andywest
    andywest over 8 years ago in reply to Gough Lui +3 suggested
    I can confirm that it was necessary to disable signed driver enforcement when I installed on Windows 10. It did work after that.
  • Gough Lui
    0 Gough Lui over 8 years ago
    It may well be possible that no signed drivers exist for Windows 10. You may be able to get around it by disabling signed driver enforcement - do a search for this and you will find a few hints on how to do it, but even then the drivers may not install.
    Just like some of the older Xilinx FPGA boards, you may find that you have to use a machine or a virtual machine running Windows 7 to be able to install and run the development tools and necessary drivers.
    - Gough
    0 genebren over 8 years ago
    Robert,
    http://www.terasic.com.tw/wiki/Altera_USB_Blaster_Driver_Installation_Instructions
    Here is a link to where you can download Quartus II
    https://www.intel.com/content/www/us/en/programmable/downloads/download-center.html
    I hope that this helps.
    Gene
  • rgiguere
    0 rgiguere over 8 years ago in reply to genebren
    Thanks for the info but ive done it that way already and i have quartus installed its ridiculous that Intel cant keep updated drivers!
  • rgiguere
    0 rgiguere over 8 years ago in reply to Gough Lui
    Thank you i will try that also can anyonr sugest a better board maybe one that the drivers work for and is compatible with windows 10
  • andywest
    0 andywest over 8 years ago in reply to Gough Lui
  • rgiguere
    0 rgiguere over 8 years ago in reply to andywest
    Great thsnks for confirmation
    0 michaelkellett over 8 years ago
    Which dev board are you using and are you using a genuine Altera blaster.
    I've found that the unofficial but very cheap USB Blaster clones can have issues but that the real thing from Altera/Intel works every time (Windows 7)
    Is there any special reason that you are using MAXII - it's a very old device, the latest generation are MAX10 which have some significant advantages.
  • rgiguere
    0 rgiguere over 8 years ago in reply to michaelkellett
    The board i have is the epm240 the blaster says Altera usb blaster the reason im using it is becaise im a student and money is a little tight it was the cheapest one offered im begining to find out why i was able to get the driver installed by disabling the driver signature enforcement temporarily but when i started Quartus it said that Jtag needs permission and everytime i hit accaept windows 10 goes into a blue error screen that says "pfn list corrupt " then restarts
    0 michaelkellett over 8 years ago in reply to rgiguere
    I can think of lots of things to try but I am kind of shooting in the dark on this:
    Try using Windows 7 (if you have that option)
    Post pictures of your board and blaster (where did you get them and how much did you pay - these are often indicators of what they might be.)
    I've had reasonable results with a cheap Chinese "Blaster" (ie it worked OK but caused conflicts with other USB devices).
    A quick look on Aliexpress shows that even an obvious clone (£2.11 price gives it away !!) still says ALTERA on it.
    https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20181030085726&SearchText=fpga+altera+blaster
    You could try a few of these (if you can wait for them to turn up).
    The official USB2Blaster from Intel/Altera is $225 from Digikey, the Terrasic Blaster (probably OK) is $50 from Digikey.
    I've used this kit:
    https://kamami.com/boards/561438-maximator-promo-with-expander-shield-and-kamami-usb-blaster.html
    and it works OK
    There's  a blog (from me) about it on E14 here:
    Kamami MAXimator FPGA Board
  • rgiguere
    Ok so mine was orderwd from amazon and it dis come from china i made the mistake of assuming it was altera because the name is all over it but obviously as you stated its a clone (45 dollars with shipping)  i think im goining to go ahead and order the one in the link you sent and see how I come out on it using windows 10 thank you for all your info and input as this is quite a learning curve for me
