FPGA
FPGA
Forum Spartan-3 download
  • Replies 11 replies
  • Answers 6 answers
  • Subscribers 582 subscribers
  • Views 4088 views
  • fpga
Spartan-3 download
philo73
philo73 over 5 years ago
Hello!
Thanks to your help (link bellow), I could make my first design, and generate PROM file with iMPACT.
But when I start Configure Target Device, I get this:
"An iMPACT project file exists, but no target device has been designated. Click OK to open iMPACT. You will then need to designate which device in your configuration chain is the target device ...... "
Is this a bug, or I really missed something? I have attached some console-log of iMPACT.
(https://www.element14.com/community/message/303328/l/which-ise-for-avnet-spartan-3a-kit#303328 )
Regards
iMPACT-log.txt.zip
    Jan Cumps over 5 years ago in reply to philo73 +3
    You may be out of luck then. The files from sourceforge are also gone. And most of the search links on google related to this kit aren't active anymore.
    shabaz over 5 years ago +3 suggested
    Hi Peter, It is possible to directly program the bitfile for almost any Xilinx chip from (say) a Pi, e.g. see here: https://github.com/yuyomagico/rpi-jtag-spartan3 Another example here using a BeagleBone…
  • philo73
    philo73 over 5 years ago in reply to bhfletcher +2
    Hi, Thanks for the reply. But this is different issue. My iMPACT doesn't crush. It opens nicely every time. My problem is this missing target target device message, despite the fact I set the target device…
  • bhfletcher
    0 bhfletcher over 5 years ago
    Looks like this may have been a common problem back the. See this Xilinx forum post for an alternative method of launching.
    https://forums.xilinx.com/t5/FPGA-Configuration/Xilinx-14-7-Impact-error/td-p/675370
    Bryan
  • philo73
    0 philo73 over 5 years ago in reply to bhfletcher
    My problem is this missing target target device message, despite the fact I set the target device. (at least I can see the target in the schematic view: two items: one bit-file and the FPGA)
    Maybe I should try batch run anyway.
  • bhfletcher
    0 bhfletcher over 5 years ago in reply to philo73
    Which JTAG cable are you using?
    Bryan
  • bhfletcher
    0 bhfletcher over 5 years ago in reply to bhfletcher
    Maybe this is it
    https://forums.xilinx.com/t5/FPGA-Configuration/DLC10-iMPACT-on-win10pro-issue/m-p/918016
    " Xilinx ISE 14.7 and IMPACT 14.7 Lab tools are not officially supported for Windows 10. So, you need to use workaround provided at https://www.xilinx.com/suppor t/answers/62380.html for Xilinx ISE 14.7 to make it work on Windows 10 platform."
    Sorry about that. Seems odd that Xilinx would create a Win-10 compatible set of tools but then have a key component not work, but it appears that is the case here.
    Bryan
  • philo73
    It is not JTAG, but PSoC MiniProg by Cypress: CY3217CY3217.  The kit is USB-powered.
    (AVNET SPARTAN-3A Evaluation Kit)
    0 Jan Cumps over 5 years ago in reply to philo73
    This (alledgedly. I could find no active support page, group, for this kit anymore) software with driver for that combination still seems to be available. https://avprog.software.informer.com/versions/
  • philo73
    0 philo73 over 5 years ago in reply to Jan Cumps
    Download from that link is not working.
  • jc2048
    0 jc2048 over 5 years ago in reply to philo73
    What's the Cypress programmer for. Are you trying to reprogram the microcontroller? Probably best not to at this point, unless you know the fpga/flash programming stuff is missing and you're trying to restore it back to what was originally there.
    This looks like it's the manual for the programming utility that Avnet supplied for programming the FPGA.
    http://www.public.asu.edu/~kyle135/Supplementary/FPGA/SPARTAN3A/User%20Guide/Avnet%20Programming%20Utility%20(AvProg)%204.05%20User%20Guide.pdf
    IMPACT, within ISE, won't know anything about this board (they wouldn't have had a separate programming utility if they'd done a deal with Xilinx to build it into IMPACT).
    The utility looks like it was written for XP/Win 7. You might get it to run on something more recent.
    0 shabaz over 5 years ago
    Hi Peter,
    Another example here using a BeagleBone Black, not tested for many years though:
    BBB - FPGA / CPLD Programmer for the BeagleBone Black
    There are lots of examples of source code doing this, because Xilinx published the core code to do it, and it can connect to microcontroller boards with no additional interfacing circuitry required.
    I don't know if this is what you're trying to do, or if your particular board doesn't expose the JTAG connections and you are forced to use the existing USB connection, in which case please ignore.
