FPGA
FPGA
Forum Avnet scripts 2021.1 - Vitis error
  • Subscribers 579 subscribers
  • Views 2226 views
bartokon
bartokon over 4 years ago
I'm trying to build Vitis project for mz7010_som using Avnet github scripts, but I can't make it work
I can build petalinux manually by using make script in petalinux folder but then:
Any ideas?
  • narrucmot
    narrucmot over 4 years ago in reply to bartokon +3
    There appears to be something wrong with the Vitis make script. I will have to look into that. In the meantime a workaround I have found is to build the PetaLinux BSP first using the build script in the…
  • narrucmot
    narrucmot over 4 years ago +1
    Do you have the 2021.1 branches checked out on the hdl, petalinux, and vitis repositories? --Tom
  • bartokon
    bartokon over 4 years ago in reply to narrucmot +1
    Hello Tom,
  • narrucmot
    0 narrucmot over 4 years ago
    --Tom
  • bartokon
    0 bartokon over 4 years ago in reply to narrucmot
    Hello Tom,
  • bartokon
    0 bartokon over 4 years ago in reply to bartokon
    narrucmot what is your building method for that scripts? I guess it is working fine for you :)
  • narrucmot
    0 narrucmot over 4 years ago in reply to bartokon
    There appears to be something wrong with the Vitis make script.  I will have to look into that.  In the meantime a workaround I have found is to build the PetaLinux BSP first using the build script in the PetaLinux repository (<>/petalinux/scripts/make_mz7010_som_base.sh):
    Then go to the Vitis repository to build the Vitis platform and vadd example (<>/vitis/make mz7010_som step=allplus):
    With this workaround the Vitis make script will automatically detect that the BSP is already created and not attempt to build it.
    --Tom
  • bartokon
    Thanks, I will test that Slight smile
  • bartokon
    Hello again,
    narrucmot
    I have tried your method but still,
